Water jet cutter machining( Development and production of prototype/Small-scale production / Blank cutting ) |
Cutting( Development and production of prototype/Small-scale production / Blank cutting ) |
Thick plate (over 6 mm)( Development and production of prototype/Small-scale production / Blank cutting ) |
Thin plate (below 6 mm)( Development and production of prototype/Small-scale production / Blank cutting ) |
Stainless steel( Development and production of prototype/Small-scale production / Blank cutting ) |
Copper/Aluminum( Development and production of prototype/Small-scale production / Blank cutting ) |
Ceramic( Development and production of prototype/Small-scale production / Blank cutting ) |
Company name |
横山機工 株式会社 (Yokoyamakikou) |
Website URL | https://www.yokoyamakiko.jp |
Street address |
Osaka Japan
[See map] |
Person in charge | - |
Capital | 30,000,000 JPY | Employees | 35 |
Annual sales | 1,700,000,000 JPY | EMIDAS Member Number | 87287 |
Type of manufacturing | Industrial machinery / Construction material / Medical equipment |
Large | Medium | Small |
Designing | Test | Specimen processing |
Material | Steel component distribution | Chequered plate Other steel plates and straps Shaped steel Flat steel plate |
Material | Nonferrous metal distribution | Plate Flat steel plate Steel (round) bar Copper and brass products Titanium Pipe material Magnesium |
Material | Plastic material distribution | PVC (polyvinyl chloride) ABS resin Fluororesin GFRP (glass fiber reinforced plastic) PU (polyurethane) |
Development and production of prototype/Small-scale production | Machining | Iron Stainless steel High rigid material Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Nickel alloy Molybdenum alloy Ceramic Sintered metal Casting Titanium Urethane Sponge Brass |
Development and production of prototype/Small-scale production | Blank cutting | Cutting Water jet cutter machining Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Ceramic Acrylic Other resins |
Mass production | Mechanical processing | Iron Stainless Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Nickel alloy Molybdenum alloy Ceramic Sintered metal Titanium Urethane Sponge |
Mass production | Plastic | Fluororesin GFRP (glass fiber reinforced plastic) Urethane resin PU (polyurethane) CFRP (carbon fiber reinforced plastic) |
Mass production | Rubber | Silicon rubber Butyl rubber NBR SBR CR EPT Fluoro-rubber Acrylic rubber Packing-related products Medical Weather-ability Thermostability Chemical proof Machine tools/Equipments Manufacturers Architecture |
Mass production | Blank cutting | Water jet processing Thick plate 6 mm or more stainless ceramic acrylic Polyimide Other resins |
