Most recent update: 2011-02-09
Recommended (best match) |
Website |
Icon |
Company info
| Company name |
深セン市融達飛科技有限公司 (Shinnsennshiyuudatsuhikagiyuugennkoushi) |
EMIDAS Member Number | 85136 |
| Country | People's Republic of China | Street address |
| Type of manufacturing | Office automation equipment / Jigs and tools / Home electrical appliances | Capital | 50,000,000 JPY |
| Annual sales | Unregister | Employees | 1500 |
Manufacturing category info
Handles mass production( Parts manufacturing / Electric board and electronic part ) |
Sintered metal( Development and production of prototype/Small-scale production / Machining ) |
Forging( Assembly/Inspection / Inspection ) |
| Large | Medium | Small |
| Designing | Electrical planning | Eletronic circuit designing Eletronic circuit designing Eletronic circuit designing Software designing Other electronic part designing Firmware designing PCB designing PLD/FPGA designing Electrical machinery and apparatus designing |
| Designing | Industrial equipment designing | Precision automatic machinery designing Automatic machinery manufacturing Carrier machine designing Plant equipment designing Food industry machinery designing Energy-saving machinery designing Industrial machinery designing |
| Designing | Jig and tool designing | Mass production jig designing Automatic tool designing Welding jig designing General jig designing General-purpose jig designing |
| Designing | Mold designing | NC data creation (press) Casting die designing Extrusion molding die designing Progressive die designing (auto) Injection molding die Progressive die designing (light electrical) Porous plastic die Forging die designing Drawing metal press die designing General metal press die NC data creation (plastic) 3D modeling (plastic) Transfer press die designing 3D modeling (press) |
| Designing | Product and part designing | Gear designing Pressure container designing Measurement/testing device designing Office equipment designing Model designing External design Wooden product designing Medical equipment designing |
| Designing | Simulation | 3D modeling Thermal analysis CAE fluid analysis Wind tunnnel simulation Transmission path simulation |
| Designing | Test | Specimen processing Destructive test Investigative research Nondestructive test Chemical analysis |
| Material | Steel component distribution | Stainless steel spring Cast-iron pipe Hot-rolled steel plate Free-machining steel Steel forgings Pickled steel plate Shaped steel Perforated metal Electroplated steel plate Shaped stainless steel Expanded metal Flat steel plate Stainless steel pipe Spring steel Deck plate Hot-dipped steel plate Cold-rolled steel plate Colored steel plate Railroad track Tool steel Other shaped steel bars Tin Other steel pipes Chequered plate Rectangular steel pipe Roof deck Wires Seamless steel pipe Heavy plate Welded steel pipe Drawn steel pipe Other steel plates and straps Steel castings Stainless steel Steel (round) bar Galvanized steel sheet |
| Material | Specialized material distribution | 42 alloy Clad steel Nickel chromium alloy Tin/Zinc based alloy Kovar Molybdenum alloy Magnetic steel sheet Ceramic material Phosphor bronze Tantalum Permanent magnet |
| Material | Nonferrous metal distribution | Plate Steel bars and shapes Nickel Coils Flat steel plate Copper and brass products Pipe material Others Steel (round) bar Titanium Magnesium |
| Material | Plastic material distribution | GFRP (glass fiber reinforced plastic) PP (polypropylene) PMMA (polymethyl methacrylate) PET (polyethylene terephthalate) PBT (polybutylene terephthalate) PEEK (polyetheretherketone) Fluororesin PU (polyurethane) Elastomer FRP (fiber reinforced plastic) PF (phenol-formaldehyde) Acetone EP (epoxy) PVC (polyvinyl chloride) PE (polyethylene) PA (nylon/polyamide) PC (polycarbonate) PPE (polyphenyl ether) PPS (polyphenylene sulfide) LCP (liquid crystal polymer) Urethane resin Butylene PES (polyethersulfone) ABS resin PS (polystyrene) POM (polyoxymethylene) PI (polyimide) |
| Development and production of prototype/Small-scale production | Machining | Aluminum alloy Nickel alloy Machining (resin) Sintered metal Stainless steel Copper alloy Molybdenum alloy Milling (resin) Casting Handles microfabrication High rigid material Magnesium alloy Keyway milling Spinning Honing Router machining General-purpose lathe machining Planer machining Simultaneous 5-axis machining Profile milling Machining/Handles small-scale production (order from 1 piece) Air chuck equipment pipe manufacturing Shaper machining Tapping Plano miller machining Tube drawing Rolling Broaching Automatic lathe Handles microfabrication Titanium alloy Lathe machining (resin) Titanium Bench lathe machining Gear hobber Straightening General-purpose milling Melt cutting Deep hole drilling Thread-cutting Ceramic Iron Sintered metal |
| Development and production of prototype/Small-scale production | NC machining | NC facing NC milling NC vertical lathe NC lathe machining Boring milling Machining (vertical) 5-face/5-axis machining Machining (horizontal) Handles 2.5-dimensional processing Combined lathe machining Five-face machining Handles 3D processing |
| Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
| Development and production of prototype/Small-scale production | Sheet-metal processing | Thin wall (Thickness Air-conditioning equipment manufacturing Angle machining 3D pipe machining Hair line machining 3-roll bending (2 m or longer) Precision sheet metal machining Swaging Kitchen unit manufacturing Chassis manufacturing Pipe machining Coating Bending (servo) Pipe bending 3-roll bending Bending (hydraulic) Deburring Can manufacturing Can manufacturing (over 5 m) NC set press Sheet metal protocol manufacturing Bending (over 3.0 m) Mirror surface machining |
| Development and production of prototype/Small-scale production | Blank cutting | Water jet cutter machining Other resins Etching Turret punch press processing Precision cutting YAG laser machining Metal mask manufacturing Nitrogen cutting UV laser machining 3D laser machining Dry etching (routing) Laser and turret punch press processing CO2 laser machining Laser marking Glass laser machining Corner shearing Electron beam machining Thin plate (below 6 mm) Acrylic Shearing Ceramic PI (polyimide) Copper/Aluminum Stainless steel Cutting Excimer laser processing Laser processing (longer than 121.2 m) Thick plate (over 6 mm) Shearing (longer than 121.2 m) Microfabrication (laser machining ) |
| Development and production of prototype/Small-scale production | Grinding processing | Jig grinding NC plane grinding Form grinding Gear grinding NC cylindrical grinding Cylindrical grinding Centerless grinding Plane grinding Cylindrical mirror grinding Profile grinding Jig boring Internal grinding NC internal grinding Thread grinding |
| Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Jig and tool manufacturing Mass production jig manufacturing Welding jig manufacturing |
| Development and production of prototype/Small-scale production | Prototype processing | Welding Model manufacturing Photoforming Bending Porous plastic prototype Punching Molten resin method Plaster casting prototype Small-size prototype manufacturing Chassis prototype manufacturing Powder sintering Fused Deposition Molding (FDM) Vacuum injection molding Plastic protocol machining Aluminum die-casting Sheet lamination |
| Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Arc welding TIG welding (argon welding) Brazing Friction welding Other bonding methods Hot plate welding Vibration welding Seam welding CO2 welding Brazing Submerged arc welding Capacitator spot welding YAG laser machining Non-contact hot plate welding Ultrasonic welding Impulse welding High-frequency welding Stud welding Semiconductor laser welding Spot welding Plasma welding High-frequency welding Robot welding Plastic bonding Infrared welding |
| Die manufacturing | Press die | Designing Roll forming die Single press die Manufacturing Transfer press die Below 60 t Over 300 t Plate machining Bending die Compound die Part processing Progressive die 3D modeling Die set machining Multi forming die Forming die NC data creation Fine blanking die Sash molding die Press robot die Blanking die Drawing die 60 - 300 t Shaving die |
| Die manufacturing | Plastic mold | Thermoset resin die Injection molding die Metal injection molding die Extrusion molding die Electrode manufacturing Rotational/Slash/Dip molding die Expansion molding die 60 - 300 t Designing Manufacturing Mold base machining Part processing NC data creation Injection molding die for microfabrication (5 mm or smaller) Over 300 and less than 1 000 t Below 60 t Thixo-molding die Thin wall injection molding die Light guide plate molding die manufacturing Plate machining 3D modeling Insert molding die Cassette-type molding die Outsert molding die Aspherical lens molding die manufacturing RTM die Vacuum/Air pressure molding die Blow molding die Core and cavity machining Plastic magnet molding die 1 000 t and over |
| Die manufacturing | Glass mold | Auto glass parts die Automatic glass-molding die Spherical lens molding die Glass mold designing & manufacturing Glass craft molding die Laboratory glass manufacturing 3D modeling Aspherical lens molding die Other glass molding die |
| Die manufacturing | Rubber mold | Part processing 3D modeling Rubber mold part processing Compression molding die Transfer molding die Home electrical appliances Packing-related products Blanking die Mobile phones Light electrical/earthing rubber Cameras binoculars and optical products Tire wheel and other auto parts Sundries and shoes Medical Designing |
| Die manufacturing | Powder metallurgy mold | Manufacturing Metal die Powder metallurgy mold part manufacturing Ferrite die Ceramic die High rigid die |
| Die manufacturing | Spring mold | Designing Manufacturing Spring die part processing Wire spring die Leaf spring die |
| Die manufacturing | Forging die | NC data creation Manufacturing Cold forging die Press forging die Upsetter forging die Forging die part processing Ring forging die Designing Hot forging die Header die Warm forging die |
| Die manufacturing | Casting die | Wooden model Manufacturing Lost-wax casting die Die-casting die Sand casting die Shell moulding die Designing 3D modeling Die-casting part processing NC data creation |
| Mass production | Mechanical processing | Honing machining Magnesium alloy Automatic screw machining Electrical discharge machining Tapping machining Wire machining Gear cutting machining Broaching machining Five-face/axes machining Aluminum alloy Titanium alloy Stainless Turning machining(plastic) Molybdenum alloy Sintered metal Screw cutting machining Micro-hole machining Ceramic Nickel alloy Rolling machining Spinning Titanium Fine particle material accepted Casting Iron Cemented carbide NC turning machining Copper alloy Air chuck equipment NC milling machining Complex turning machining Machining |
| Mass production | Metal press | Multi forming Coining Bending Press robot (below 80 t) Press robot (over 500 t) Transfer press (200 - 500 t) Single press (below 80 t) Single press (500 t and over) Progressive press (80 - 200 t) φ0.6mm - φ9.0mm Diameter Phosphor bronze Plated steel plate Thickness Stainless steel Blanking Stainless steel material for spring Brass Single press (200 - 500 t) Titanium Aluminum Roll forming Progressive press (over 500 t) Iron Progressive press (35 - 80 t) Corson alloy Single press (80 - 200 t) Shaving Bulge forming die Transfer press (below 80 t) Transfer press (over 500 t) Nickel Progressive press (200 - 500 t) Beryllium copper Drawing Press robot (200 - 500 t) Copper Transfer press (80 - 200 t) Fine blanking Diameter Hydraulic counter pressure press Forming Thickness Combined press-joining Warm forming press Thickness Press robot (80 -200 t) Thickness |
| Mass production | Plastic | Biodegradable plastic Injection molding Outsert molding Thin wall molding PEEK (polyetheretherketone) GFRP (glass fiber reinforced plastic) Engineering plastic Over 1 000 t Gas injection Special shape extrusion molding FRP molding (RTM BMC SMC) Film-lamination Ceramic injection (CIM) Insert molding Below 60 t Tube extrusion molding Thermoset resin PMMA (polymethyl methacrylate) PES (polyethersulfone) 300 - 1 000 t FRP molding (CFRP auto-crape) PVC (polyvinyl chloride) Inflation molding Thermoset resin Air pressure molding Extrusion molding Handles small-scale production FRP (fiber reinforced plastic) Porous plastic molding Dual molding Vacuum molding Plastic magnet molding 60 - 300 t Metal injection molding (MIM) Urethane resin Rotational/Slash/Dip molding Film (calender) molding Owns dies of commercially availalable size LCP (liquid crystal polymer) Fluororesin Elastomer PI (polyimide) PPS (polyphenylene sulfide) Expansion molding Blow molding FRP molding (hand lay-up/spray lay-up) Thixo-molding Pipe extrusion molding PBT (polybutylene terephthalate) General-purpose material CFRP (carbon fiber reinforced plastic) PU (polyurethane) EP (epoxy) |
| Mass production | Glass/Silicon | Glass substrate Optical fiber Optical thin film products Slicing/Dicing Glass craft manufacturing Spherical lens Specialized filter Laboratory glass manufacturing Lens hand polishing Glass mirror polishing Auto glass parts manufacturing Toughened glass manufacturing Glass microfabrication Glass welding Aspherical lens Microblast Other glass manufacturing Ultrasonic machining |
| Mass production | Rubber | Super-size machining Transfer molding Sundries and shoes Silicon rubber Home electrical appliances Fluoro-rubber Compression molding Urethane rubber Rubber product prototype manufacturing NBR Tire wheel and other auto parts Blanking Cameras binoculars and optical products SBR EPT CR Medical Mobile phones Butyl rubber Packing-related products Acrylic rubber Light electrical/earthing rubber Press stamping |
| Mass production | Powder metallurgy | Ceramic Ferrite Over 5 kg Metal Below 500 g High rigidity 500 g - 5 kg |
| Mass production | Die-casting | 250 - 1 000 t Over 1 000 t Aluminum Zinc 125 t or less Magnesium alloy 125 - 250 t |
| Mass production | Casting | 5 kg and over Aluminum bronze alloy Prototype casting Metal injection molding (MIM) Gravity casting Sand casting Pressure casting Precision sand casting Cast-iron Low-pressure casting Plaster casting Copper alloy Cast steel Die-casting Lost-wax Ductile cast iron 500 g and below Shell moulding Zinc alloy Stainless steel Aluminum alloy Centrifugal casting Over 500 g and less than 5 kg Magnesium alloy |
| Mass production | Forging | Drop hammer Cold forging Forging roll Hot forging Header machining Below 500 g Over 5 kg Brass Upsetter forging Free forging Aluminum Pressure forging Ring forging 500 g - 5 kg Press forging Iron High-strength brass Corson alloy Others Warm forging |
| Surface treatment | Plating/Chemical conversion treatment | Electroless nickel (barrel) Baking (hydrogen embrittling) Black chromate (black/green) Colored chromate (multi-color) Nickel (rack) Parkerizing (phosphate film) Chromium (barrel) Chromate (general) Electroless nickel (rack) Zinc die-cast Stainless steel Zinc (rack) Electrocasting Solder (barrel) Black oxide finish Alumite (anode oxidation) Other anti-rust treatments Magnesium Hard chromium (rack) Hot-dip galvanizing (large-size Nickel (barrel) Plastic Hot-dip aluminum plating Dacrotizing Unichromate (white) Copper (rack) Hot-dip galvanizing (mid-size Aluminum Titanium Tin (barrel) Chemical conversion coating Gold/Silver plating Iron Black chromium (barrel) Aldine treatment (aluminum chromate) Trivalent Chromate (barrel plating) Copper Hot-dip galvanizing (small-size Brass Rhodium Nickel chromium (rack) Copper (barrel) Tin-zinc alloy plating (rack) Hard alumite Electroless copper (rack) Acid pickling Chromium (rack) Degreasing Tin (rack) Zinc (barrel) Black chromium (rack) Colored alumite Electroless copper (barrel) |
| Surface treatment | Coating | UV resistant coating Ceramic coating Lacquer coating Transfer printing Wood coating Epoxy coating Acrylic coating Electrostatic coating Heat-resistant coating Flock coating Electrodeposition coating Airless spray coating Metal coating Heat insulation coating Melamine coating Resin coating Aqueous coating Fluorine coating Electrical insulating Powder coating Urethane coating EMI shielding coating Air-spray coating |
| Surface treatment | Polishing/Lapping | Barrel finishing (vibration) Mirror polishing Rap polishing Tool polishing Single-face lapping and polishing Electropolishing Buffing Brush polishing Chemical polishing Barrel finishing (rotation) Barrel finishing (centrifugal) Dual-face lapping and polishing Blade polishing Rap mirror polishing |
| Surface treatment | Printing and others | Printing Engraving Pad printing NC engraving Offset printing Silk screen printing Hot stamping (gold embossing) Gravure printing Silk (handles curved surface) |
| Surface treatment | Heat treatment | Air quenching Vacuum annealing Stress relief annealing (SR treatment) Vacuum quenching Gas nitrocarburizing Full annealing Vacuum normalizing Normalizing Straightening annealing Quenching Austempering Carburized quenching Salt bath quenching Flame quenching Sub-zero treatment High frequency quenching Annealing Salt bath soft nitriding (tufftriding) Solution heat treatment Nitridation |
| Surface treatment | Other surface treatment | Spattering Teflon coating Carbide Dispersion/TD Tool and die coating Resin impregnation Shot blast Glass beads blast Arc spray Coating Sound blast Frame spraying High-speed frame spraying (HVOF) Exploded spray (HEPD) Ionized plating Water blast Thermal oxidation Vacuum deposition Etching (surface treatment) Spraying Plasma spray Buffing Shot peening/WPC Other physical vapor deposition methods (PVD) Dry type lubricant coating CVD (chemical vapor deposition) DLC coating |
| Assembly/Inspection | Assembly | Auto parts assembly Toy and sundries assembly Precision equipment assembly Construction component assembly Industrial machinery assembly Office equipment assembly |
| Assembly/Inspection | Inspection | Metal press Spring Rubber Measuring Glass Bolt/Screw/Nut Plastic Powder metallurgy Casting Forging |
| Assembly/Inspection | Repair | Machine tool repair Auto parts repair Construction repair Office equipment repair Industrial machinery repair Precision equipment repair Die repair |
| Parts manufacturing | Machinery part | Vacuum components manufacturing Valve manufacturing Pressure container manufacturing pipe manufacturing Gear manufacturing Bearing manufacturing Optical parts manufacturing Shaft and roller manufacturing Crank shaft manufacturing Connection parts manufacturing Measurement devices manufacturing Magnet containing products manufacturing |
| Parts manufacturing | Electrical part | Switch manufacturing Transformer manufacturing Coil manufacturing Other electrical part manufacturing Cable manufacturing Cord manufacturing Harness processing Power-supply device manufacturing Connector manufacturing |
| Parts manufacturing | Electric board and electronic part | Large current board Rigid board Membrane switch Electronic parts assembly and wiring Impedance control system Handles short delivery Flexible board manufacturing Rigid board parts mounting IVH (inner via hole) BVH (blind via hole) Semiconductor and other general stock Handles one side Fine pattern board Handles both sides Multilayer board Flexible board parts mounting Protocol and small-scale (PCB) Build-up board Handles mass production |
| Parts manufacturing | Spring | Diameter Leaf spring Carbon steel Spring washer Terminal spring Formed wire spring Piano wire (carbon wire) Compression coil spring Double torsion spring Volute spring Thin leaf spring Battery spring Copper alloy Stainless steel Shaped spring Tensil coil spring Diameter Torsion spring Conical spring Diameter Torsion spring |
| Parts manufacturing | Bolt/Screw/Nut | Bolt/Screw/Nut manufacturing Screw manufacturing Nut manufacturing Bolt manufacturing Screw manufacturing |
| Parts manufacturing | Other parts | Lock manufacturing Sign board manufacturing Filter manufacturing Blade manufacturing Chain manufacturing Model manufacturing Metallic mesh manufacturing |
| Auto parts manufacturing | Body part | Bumper Door mirror Grill Door lock Fender Door Other body parts |
| Auto parts manufacturing | Drive system part | Steering device Clutch Transmission Brake parts Drive shaft Caliper Accelerator |
| Auto parts manufacturing | Engine | Radiator parts Muffler Fuel system Cooling system Ignition system |
| Auto parts manufacturing | Exterior part | Wiper Spoiler Roof box |
| Auto parts manufacturing | Interior part | Communication accessories Audio components Seat parts |
| Product manufacturing | Production property | Measurement/testing devices manufacturing Brush manufacturing Lubrication equipment manufacturing Carrier machine manufacturing Blade manufacturing Brush manufacturing Blade manufacturing Electrical machinery and apparatus manufacturing Freezer equipment manufacturing Other industrial machinery manufacturing Packaging machinery manufacturing Cardboard box manufacturing Optical products manufacturing Industrial robot manufacturing Hydraulic pressure equipment manufacturing Information equipment manufacturing Monitoring device manufacturing Machine tool manufacturing Energy-saving equipment/Automatic instrument manufacturing Blade manufacturing Vacuum equipment manufacturing Environmental equipment manufacturing Blade manufacturing Chemical industry machinery and equipment manufacturing Chemical product manufacturing Semiconductor manufacturing equipment manufacturing Monitoring device manufacturing Industrial furnace/Test furnace manufacturing Food industry machinery manufacturing LCD manufacturing Brush manufacturing Coating equipment manufacturing Vacuum equipment manufacturing Stamp manufacturing Chemical industry machinery and equipment manufacturing Monitoring device manufacturing Chemical industry machinery and equipment manufacturing Industrial furnace/Test furnace manufacturing Industrial furnace/Test furnace manufacturing Fluid equipment manufacturing |
| Product manufacturing | Plant equipment manufacturing | Plant equipment manufacturing Large-size plant apparatus manufacturing Steel and furnace apparatus manufacturing Hydro/thermal/electric/atomic power generation apparatus manufacturing Marine vessel equipment manufacturing |
| Product manufacturing | Construction and civil engineering machinery manufacturing | Construction and civil engineering material manufacturing Lavatory products manufacturing Pipe connection Interior and outer wall material manufacturing Civil engineering machinery manufacturing Sound/fire/water proof material manufacturing Water supply and discharge system manufacturing Kitchen sink manufacturing Combustor manufacturing Construction machinery manufacturing |
| Product manufacturing | Medical equipment manufacturing | Dental products Inspection and testing devices Surgical instruments Medical equipment manufacturing |
| Product manufacturing | Household commodity | Office equipment manufacturing Pot rice-cooker and kettle manuacturing Bath products manufacturing Storage products Laundry products manufacturing Cutlery Outdoor leisure product manufacturing Plates and glasses |
| Product manufacturing | Furniture/Interior | Leather product manufacturing Lighting equipment manufacturing Nameplates Fabric product manufacturing Bedclothing manufacturing |
| Product manufacturing | Craftwork/Event and ceremonial goods | Crystal glass products manufacturing Crockery manufacturing Glass products manufacturing Wooden product manufacturing Stone products manufacturing Bamboo (craft) products manufacturing Paper product manufacturing |
| Product manufacturing | Machinery and product manufacturing | Paper product manufacturing |
| Product manufacturing | Food industry machinery manufacturing | Other food industry machinery manufacturing Food manufacturing Energy-saving fishery machinery manufacturing Energy-saving livestock-farming machinery manufacturing |
| Product manufacturing | Environmental equipment manufacturing | Noise-reduction system manufacturing Recycling system manufacturing Waste water treatment system manufacturing |
| Product manufacturing | Watch/Glasses/Accessory/Jewelry | Bracelet and buckle manufacturing Clock assembly/manufacturing Jewerly parts manufacturing Watch assembly/manufacturing Necklace and pendant manufacturing Earring manufacturing Ring manufacturing Eye-glass frame and lens manufacturing |
| Product manufacturing | Others | Transportation equipment manufacturing Telecommunication equipment manufacturing Welfare equipment manufacturing |
Shinnsennshiyuudatsuhikagiyuugennkoushi (深セン市融達飛科技有限公司)
