Laser and turret punch punching( Mass production / Blank cutting ) |
Laser processing (over 1.2m)( Mass production / Blank cutting ) |
Machining( Mass production / Mechanical processing ) |
Complex turning machining( Mass production / Mechanical processing ) |
Bender processing (servo)( Mass production / Sheet-metal processing ) |
Turret punch punching( Mass production / Blank cutting ) |
TIG welding (argon welding)( Mass production / Welding / welding ) |
Company name |
株式会社 双葉電機製作所 (Kabushikikaisha futabadennkiseisakusho) |
Website URL | http://www.futaba-dk.co.jp |
Street address |
Chiba Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 15 |
Annual sales | Unregister | EMIDAS Member Number | 83752 |
Type of manufacturing | Industrial machinery / Medical equipment / Telecommunication equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Thread-cutting Spinning Iron Stainless steel Aluminum alloy Titanium alloy Machining (resin) Sintered metal Keyway milling Milling (resin) Lathe machining (resin) Casting Titanium Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) Additional-axis machining NC milling NC lathe machining Combined lathe machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Deburring Coating Hair line machining 3-roll bending Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser and turret punch press processing Laser processing (longer than 121.2 m) Shearing (longer than 121.2 m) Corner shearing Stainless steel Copper/Aluminum Acrylic |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding TIG welding (argon welding) Plasma welding Arc welding Brazing Stud welding Capacitator spot welding |
Development and production of prototype/Small-scale production | Prototype processing | Welding Small-size prototype manufacturing Chassis prototype manufacturing |
Development and production of prototype/Small-scale production | Blank cutting | Laser marking YAG laser processing Turret punch punching Shirring Cutting process Laser and turret punch punching Laser processing (over 1.2m) Shirring (more than 1.2m) Water jet processing Connor Shah Fiber laser processing Clean cut Thin plate 6 mm or less Thick plate 6 mm or more stainless Copper / aluminum acrylic Precision cutting 3D laser |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Complex turning machining Wire machining Screw cutting machining Micro-hole machining Iron Stainless Aluminum alloy Titanium alloy Broaching machining Automatic screw machining Air chuck equipment Turning machining(plastic) Casting Titanium Ultra-thin |
Mass production | Grinding processing | Plane grinding |
Mass production | Sheet-metal processing | Precision sheet metal processing Sheet metal prototype manufacturing Painting process Bender processing (flood control) Bender processing (servo) Bending process |
Mass production | Blank cutting | Laser marking YAG laser processing Turret punch punching Shirring Cutting process Laser and turret punch punching Laser processing (over 1.2m) Shirring (more than 1.2m) Water jet processing Connor Shah Fiber laser processing Clean cut Thin plate 6 mm or less Thick plate 6 mm or more stainless Copper / aluminum acrylic Precision cutting 3D laser |
Mass production | Welding / welding | CO2 welding Spot welding TIG welding (argon welding) Robot welding Plastic adhesive Stud welding YAG laser processing |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Zinc (barrel) Chromate (general) Nickel (rack) Zinc (rack) Alumite (anode oxidation) Acid pickling Electroless nickel (rack) Iron Copper Brass Aluminum Stainless steel Other anti-rust treatments Degreasing Black oxide finish Colored alumite Hard alumite Unichromate (white) Black chromate (black/green) |
Surface treatment | Coating | Air-spray coating Melamine coating Acrylic coating Lacquer coating Metal coating |
Surface treatment | Polishing/Lapping | Electropolishing Buffing Mirror polishing |
Surface treatment | Other surface treatment | Buffing Shot blast Sound blast |
Assembly/Inspection | Assembly | Precision equipment assembly Industrial machinery assembly |
Assembly/Inspection | Side job processing | Manual labor |
Parts manufacturing | Electrical part | Harness processing Other electrical part manufacturing |
Parts manufacturing | Electric board and electronic part | Protocol and small-scale (PCB) Electronic parts assembly and wiring Handles mass production |
Parts manufacturing | Spring | Thin leaf spring Compression coil spring Tensil coil spring Leaf spring Conical spring Spring washer Torsion spring Piano wire (carbon wire) Stainless steel |
Parts manufacturing | Bolt/Screw/Nut | Screw manufacturing Bolt manufacturing |
