Copper and brass products( Material / Nonferrous metal distribution ) |
Hot-dipped steel plate( Material / Steel component distribution ) |
Pipe machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Electroplated steel plate( Material / Steel component distribution ) |
NC lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Buffing( Surface treatment / Other surface treatment ) |
Brass( Surface treatment / Plating/Chemical conversion treatment ) |
Company name | Takahashi Metal Co.,Ltd. | Website URL | |
Street address |
Gifu-shi Gifu Japan
[See map] |
Person in charge | wakahara |
Telephone number | +81-58-279-3161 | Fax number | +81-58-279-3631 |
Capital | 45,000,000 JPY | Employees | 90 |
Annual sales | 10,000,000,000 JPY | EMIDAS Member Number | 79992 |
Type of manufacturing | Industrial machinery / Telecommunication equipment / Electronic parts | ||
Main 3 products |
PR message
We are a company that handles all types of ferrous and non-ferrous metals. In our company, we have [Shindo Division] that sell and perform non-ferrous metal (copper/brass) processing , and [Special Sales Division] that sell and perform leveler/shearing of surface-treated steel sheets (steel strip).
We have subsidiary company, Tube Seisakusho Co., Ltd which specializes in copper tubes bending (terminal processing/brazing), brass tubes processing, and stainless steel tubes processing.
In addition, we also have International Business Division which focuses on overseas procurement and sales, and is engaged in global activities. Recently, we perform precision processing companies grouping of automobile parts, plug parts, aviation parts, medical parts, etc. and expand to a wider range of customers' satisfaction and trust.
Most recent update:2023-09-14
Large | Medium | Small |
Material | Steel component distribution | Pickled steel plate Stainless steel Hot-rolled steel plate Cold-rolled steel plate Electroplated steel plate Hot-dipped steel plate Tin Other steel plates and straps Flat steel plate Steel (round) bar Garubariumu steel |
Material | Nonferrous metal distribution | Plate Flat steel plate Steel (round) bar Steel bars and shapes Copper and brass products Pipe material Coils Others |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining |
Development and production of prototype/Small-scale production | Blank cutting | Shearing Shearing (longer than 121.2 m) Thin plate (below 6 mm) Stainless steel |
Development and production of prototype/Small-scale production | Grinding processing | Thread grinding |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending |
Mass production | Metal press | Iron Copper Brass |
Mass production | Mechanical processing | NC milling machining NC turning machining Tapping machining Screw cutting machining Iron Stainless Cemented carbide Aluminum alloy Copper alloy Automatic screw machining Fine particle material accepted |
Surface treatment | Plating/Chemical conversion treatment | Tin (barrel) Nickel (rack) Nickel chromium (rack) Acid pickling Copper Brass Aluminum Degreasing Black chromate (black/green) |
Surface treatment | Polishing/Lapping | Buffing |
Surface treatment | Other surface treatment | Buffing |
Parts manufacturing | Machinery part | Valve manufacturing Connection parts manufacturing |
Parts manufacturing | Bolt/Screw/Nut | Screw manufacturing Bolt manufacturing Nut manufacturing Screw manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Pipe connection |
