Blanking( Mass production / Metal press ) |
Progressive press (200 - 500 t)( Mass production / Metal press ) |
Single press (200 - 500 t)( Mass production / Metal press ) |
Single press (80 - 200 t)( Mass production / Metal press ) |
Progressive press (80 - 200 t)( Mass production / Metal press ) |
Drawing( Mass production / Metal press ) |
Bending( Mass production / Metal press ) |
Welding( Development and production of prototype/Small-scale production / Prototype processing ) |
Transfer press (200 - 500 t)( Mass production / Metal press ) |
Laser and turret punch press processing ( Development and production of prototype/Small-scale production / Blank cutting ) |
| Company name |
松本金属 株式会社 (Matsumotokinnzoku) |
Website | www.matukin.co.jp/matukin/ |
| Street address |
Hyogo Japan
[See map] |
Person in charge | - |
| Capital | 50,000,000 JPY | Employees | 140 |
| Annual sales | 6,800,000,000 JPY | EMIDAS Member Number | 79348 |
| Large | Medium | Small |
| Development and production of prototype/Small-scale production | Machining | Tapping Iron Stainless steel Aluminum alloy |
| Development and production of prototype/Small-scale production | Sheet-metal processing | Sheet metal protocol manufacturing |
| Development and production of prototype/Small-scale production | Blank cutting | Thin plate (below 6 mm) Stainless steel Copper/Aluminum Turret punch press processing Shearing Cutting Laser and turret punch press processing |
| Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending |
| Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding Robot welding |
| Mass production | Metal press | Progressive press (200 - 500 t) Blanking Iron Aluminum Drawing Bending Forming Roll forming Transfer press (200 - 500 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) Single press (below 80 t) Single press (80 - 200 t) Press robot (below 80 t) Press robot (80 -200 t) Press robot (200 - 500 t) Stainless steel Plated steel plate Thickness Thickness Thickness Diameter φ0.6mm - φ9.0mm Diameter Single press (200 - 500 t) |
| Mass production | Casting | Prototype casting Die-casting Aluminum alloy Zinc alloy |
| Mass production | Forging | Iron Aluminum Below 500 g 500 g - 5 kg Over 5 kg |
| Surface treatment | Coating | Metal coating |
| Assembly/Inspection | Assembly | Construction component assembly |
| Assembly/Inspection | Inspection | Metal press Casting Measuring |
| Product manufacturing | Production property | Electrical machinery and apparatus manufacturing |
| Product manufacturing | Construction and civil engineering machinery manufacturing | Construction and civil engineering material manufacturing |
| Product manufacturing | Furniture/Interior | Lighting equipment manufacturing |
