Most recent update: 2023-01-18
Aluminum( Mass production / Metal press ) |
Blanking die( Die manufacturing / Press die ) |
Micro hole machining( Development and production of prototype/Small-scale production / Electrical discharge machine ) |
Company name |
岩田精工 株式会社 (Iwataseikou) |
Website URL | http://www.iwataseiko.com/ |
Street address |
Kyoto Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 18 |
Annual sales | Unregister | EMIDAS Member Number | 78508 |
Type of manufacturing | Jigs and tools / Measuring machinery / Electronic parts |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Deep hole drilling Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Machining (resin) Milling (resin) Lathe machining (resin) Handles microfabrication Titanium |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Combined lathe machining Machining (horizontal) Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Precision sheet metal machining Sheet metal protocol manufacturing |
Development and production of prototype/Small-scale production | Blank cutting | YAG laser machining CO2 laser machining Microfabrication (laser machining ) Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding Plane grinding Form grinding Cylindrical grinding Profile grinding Jig grinding Cylindrical mirror grinding Internal grinding Centerless grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding TIG welding (argon welding) YAG laser machining |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Bending |
Die manufacturing | Press die | Manufacturing Part processing Plate machining Drawing die Bending die Blanking die Progressive die Single press die Compound die |
Die manufacturing | Plastic mold | Part processing Plate machining Core and cavity machining |
Mass production | Metal press | Drawing Bending Blanking Shaving Coining Iron Stainless steel Aluminum Copper Brass Phosphor bronze Plated steel plate Single press (below 80 t) Progressive press (35 - 80 t) |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Wire machining Micro-hole machining Electrical discharge machining Iron Stainless Aluminum alloy Copper alloy Titanium alloy Nickel alloy Turning machining(plastic) Titanium Fine particle material accepted |
Assembly/Inspection | Repair | Die repair |
