Most recent update: 2023-10-10
Progressive die( Die manufacturing / Press die ) |
Insert molding( Mass production / Plastic ) |
Transfer press die designing( Designing / Mold designing ) |
Company name |
株式会社 多加良製作所 (Takaraseisakusho) |
Website URL | http://www.takaras.co.jp/ |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 100,330,000 JPY | Employees | 160 |
Annual sales | Unregister | EMIDAS Member Number | 77267 |
Type of manufacturing | Telecommunication equipment / Electronic parts / Medical equipment |
Large | Medium | Small |
Designing | Mold designing | Injection molding die Progressive die designing (light electrical) Drawing metal press die designing Transfer press die designing General metal press die 3D modeling (press) 3D modeling (plastic) NC data creation (press) NC data creation (plastic) |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing |
Designing | Test | Specimen processing |
Designing | Industrial equipment designing | Automatic machinery manufacturing Precision automatic machinery designing |
Designing | Simulation | 3D modeling CAE fluid analysis |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Deep hole drilling Thread-cutting Profile milling Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Ceramic Sintered metal Keyway milling Automatic lathe Bench lathe machining Handles microfabrication |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Blank cutting | Shearing Cutting Thin plate (below 6 mm) Stainless steel Copper/Aluminum |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Form grinding Cylindrical grinding Profile grinding Jig boring Jig grinding Internal grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Punching Bending Small-size prototype manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation 3D modeling Drawing die Bending die Blanking die Forming die Shaving die Progressive die Transfer press die Single press die Below 60 t 60 - 300 t Compound die |
Die manufacturing | Plastic mold | Designing Manufacturing Part processing Plate machining Mold base machining NC data creation 3D modeling Injection molding die Insert molding die Outsert molding die Below 60 t 60 - 300 t Electrode manufacturing Cassette-type molding die Thermoset resin die Metal injection molding die Thin wall injection molding die Injection molding die for microfabrication (5 mm or smaller) Core and cavity machining |
Die manufacturing | Powder metallurgy mold | Ceramic die High rigid die |
Die manufacturing | Forging die | Cold forging die |
Mass production | Metal press | Drawing Bending Blanking Forming Shaving Coining Iron Stainless steel Aluminum Copper Brass Phosphor bronze Plated steel plate Stainless steel material for spring Thickness Thickness Thickness Beryllium copper Single press (80 - 200 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
Mass production | Mechanical processing | Machining NC milling machining Tapping machining Wire machining Screw cutting machining Electrical discharge machining Iron Stainless Cemented carbide Aluminum alloy Copper alloy Ceramic Sintered metal |
Mass production | Plastic | Insert molding Outsert molding PVC (polyvinyl chloride) General-purpose material PMMA (polymethyl methacrylate) Engineering plastic PBT (polybutylene terephthalate) PPS (polyphenylene sulfide) PI (polyimide) PEEK (polyetheretherketone) LCP (liquid crystal polymer) Fluororesin Thermoset resin GFRP (glass fiber reinforced plastic) PU (polyurethane) Below 60 t 60 - 300 t Injection molding PES (polyethersulfone) EP (epoxy) Handles small-scale production Thin wall molding Biodegradable plastic CFRP (carbon fiber reinforced plastic) |
Mass production | Forging | Press forging |
Surface treatment | Polishing/Lapping | Buffing Mirror polishing |
Surface treatment | Lap polishing | Lap polishing Lap mirror polishing |
Surface treatment | Heat treatment | Normalizing Annealing Vacuum annealing Air quenching Salt bath quenching Vacuum quenching Sub-zero treatment |
Surface treatment | Barrel polishing | Barrel finishing (rotation) |
Surface treatment | Other surface treatment | Sound blast |
Assembly/Inspection | Assembly | Industrial machinery assembly |
Assembly/Inspection | Repair | Industrial machinery repair Die repair |
Assembly/Inspection | Inspection | Metal press Plastic Measuring |
Parts manufacturing | Electrical part | Harness processing Cable manufacturing Connector manufacturing Other electrical part manufacturing Switch manufacturing |
Auto parts manufacturing | Body part | Door lock |
Auto parts manufacturing | Drive system part | Transmission |
Auto parts manufacturing | Interior part | Communication accessories Audio components |
Product manufacturing | Production property | Energy-saving equipment/Automatic instrument manufacturing Brush manufacturing Semiconductor manufacturing equipment manufacturing |
