TIG welding (argon welding)( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
NC lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Stainless steel( Development and production of prototype/Small-scale production / Machining ) |
Aluminum alloy( Development and production of prototype/Small-scale production / Machining ) |
Vacuum equipment manufacturing( Product manufacturing / Production property ) |
Machining/Handles small-scale production (order from 1 piece)( Development and production of prototype/Small-scale production / Machining ) |
Company name | Towa Industry Co., Ltd. Miyagi plant | Website URL | http://www.towa-kk.net/ |
Street address |
Ishinomaki city Miyagi Japan
[See map] |
Person in charge | Jinichi Ogasawara |
Telephone number | +81-225-96-6937 | Fax number | +81-225-96-6905 |
Capital | 10,000,000 JPY | Employees | 37 |
Annual sales | 400,000,000 JPY | EMIDAS Member Number | 75596 |
Type of manufacturing | Machine tools / Industrial machinery | ||
Main 3 products |
PR message
(Machine processing)
NC/MC/Lathe/Milling Machine/Welding/Assembly Test/Designing
(Work)
Stainless Steel/Aluminum/Steel
(Characteristics)
Single item/Small lot/post-processing, post-welding secondary processing
5 axes/ Hale machining/ Vacuum sealing finishing/ Vacuum chamber with a large machining center
We store Stainless Steel (SUS304, 316/Aluminum) for raw materials in our company all the time.
Vacuum device machining/Vacuum valves (Leak test, available)/ High pressure valve (1000k pressure, available)/ general machining/ estimate/ technology/ designing/ etc.
Our motto is “Customers are precious as god.”
Feel free to contact us!
[Sale products]
*Machine processing/ Assembly test of Special Steel (Stainless Steel, plain steel)
*Special high pressure valve, Vacuum valve, IT high-tech industrial device
* Design ~ Processing ~ Washing ~ Argon Gas Arc Welding ~ Secondary processing ~ Sale ~ Assembly ~
*Vacuum test (Helium Leak Detector/ Anelva)
High pressure test (High pressure booster/ 1000K) equipped
*Laboratories for next generation industries/ Machine parts, etc.
*Vacuum chamber/ vacuum pipe/ general machine processing
*General machine processing parts, etc.
<<Please contact us by email.>>
Most recent update:2025-04-03
Large | Medium | Small |
Designing | Product and part designing | Pressure container designing |
Designing | Jig and tool designing | General jig designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Deep hole drilling Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Titanium alloy Machining (resin) Keyway milling Milling (resin) Lathe machining (resin) Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Combined lathe machining |
Development and production of prototype/Small-scale production | Electrical discharge machine | Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Sheet metal protocol manufacturing Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting CO2 laser machining |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | TIG welding (argon welding) Arc welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Welding Bending |
Die manufacturing | Plastic mold | Electrode manufacturing |
Parts manufacturing | Machinery part | Vacuum components manufacturing Pressure container manufacturing Connection parts manufacturing |
Parts manufacturing | Electric board and electronic part | Electronic parts assembly and wiring |
Product manufacturing | Production property | Machine tool manufacturing Other industrial machinery manufacturing Electrical machinery and apparatus manufacturing Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing Chemical product manufacturing Optical products manufacturing Freezer equipment manufacturing Vacuum equipment manufacturing |
Product manufacturing | Plant equipment manufacturing | Plant equipment manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Construction and civil engineering material manufacturing |
Product manufacturing | Others | Welfare equipment manufacturing |
