Most recent update: 2010-11-16
Recommended (best match) |
Website |
Icon |
Company info
| Company name |
有限会社 山内エンジニアリング (Yamauchiennziniarinngu) |
EMIDAS Member Number | 75473 |
| Country | Japan | Street address |
Kanagawa |
| Type of manufacturing | Industrial machinery / Transportation equipment / Home electrical appliances | Capital | 3,000,000 JPY |
| Annual sales | Unregister | Employees | 3 |
Manufacturing category info
Progressive die( Die manufacturing / Press die ) |
Drawing die( Die manufacturing / Press die ) |
Transfer press die( Die manufacturing / Press die ) |
| Large | Medium | Small |
| Designing | Mold designing | Transfer press die designing Progressive die designing (auto) Drawing metal press die designing General metal press die Extrusion molding die designing Forging die designing |
| Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining Bending die Blanking die Forming die Fine blanking die Shaving die Single press die Press robot die Below 60 t 60 - 300 t Over 300 t Compound die Transfer press die Drawing die Progressive die |
| Die manufacturing | Forging die | Designing Cold forging die Press forging die Forging die part processing |
| Mass production | Metal press | Plated steel plate Stainless steel material for spring Thickness Thickness φ0.6mm - φ9.0mm Diameter Drawing Iron Bending Blanking Forming Fine blanking Shaving Coining Transfer press (below 80 t) Transfer press (80 - 200 t) Transfer press (200 - 500 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) Progressive press (200 - 500 t) Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) Press robot (below 80 t) Press robot (80 -200 t) Press robot (200 - 500 t) Stainless steel Aluminum Copper Brass Phosphor bronze Titanium |
| Mass production | Forging | Cold forging Press forging Upsetter forging Iron Aluminum Brass Others Below 500 g 500 g - 5 kg |
Yamauchiennziniarinngu (有限会社 山内エンジニアリング)
