Drawing( Mass production / Metal press ) |
Thin leaf spring( Parts manufacturing / Spring ) |
Stainless steel( Mass production / Metal press ) |
Company name |
株式会社 スギテック (Sugitekku) |
Website URL | http://www.sugitec.com/ |
Street address |
Nara Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 17 |
Annual sales | Unregister | EMIDAS Member Number | 75334 |
Type of manufacturing | Home electrical appliances / Transportation equipment |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (light electrical) Drawing metal press die designing Transfer press die designing General metal press die NC data creation (press) |
Designing | Jig and tool designing | General jig designing Mass production jig designing |
Die manufacturing | Press die | Designing Manufacturing Part processing Drawing die Bending die Blanking die Forming die Multi forming die Transfer press die Press robot die Below 60 t 60 - 300 t |
Die manufacturing | Plastic mold | Electrode manufacturing |
Die manufacturing | Spring mold | Designing Manufacturing |
Mass production | Metal press | Drawing Bending Blanking Forming Multi forming Transfer press (below 80 t) Iron Stainless steel Aluminum Copper Brass Phosphor bronze Plated steel plate Stainless steel material for spring Nickel Thickness Thickness Diameter φ0.6mm - φ9.0mm Press robot (below 80 t) Single press (below 80 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
Surface treatment | Plating/Chemical conversion treatment | Degreasing |
Assembly/Inspection | Inspection | Metal press Spring Measuring |
Parts manufacturing | Spring | Thin leaf spring Terminal spring Leaf spring Shaped spring Battery spring Conical spring Spring washer Carbon steel Stainless steel Copper alloy Diameter Diameter |
Product manufacturing | Construction and civil engineering machinery manufacturing | Construction and civil engineering material manufacturing |
