Most recent update: 2023-05-12
Injection molding ( Mass production / Plastic ) |
Company name |
甲東機工 株式会社 (Koutoukikou) |
Website URL | http://www.koto-kiko.co.jp |
Street address |
Miyazaki Japan
[See map] |
Person in charge | - |
Capital | 54,000,000 JPY | Employees | 30 |
Annual sales | 330,000,000 JPY | EMIDAS Member Number | 74303 |
Type of manufacturing | Industrial machinery / Transportation equipment / Office appliances |
Large | Medium | Small |
Designing | Mold designing | Injection molding die Progressive die designing (light electrical) Progressive die designing (auto) General metal press die |
Designing | Jig and tool designing | General jig designing Mass production jig designing |
Development and production of prototype/Small-scale production | Machining | Melt cutting General-purpose milling General-purpose lathe machining Tapping Iron Stainless steel Aluminum alloy Titanium alloy Nickel alloy Machining (resin) Titanium |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Angle machining Pipe bending Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Shearing Cutting |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing |
Die manufacturing | Press die | Designing Manufacturing Plate machining Bending die Blanking die Progressive die Single press die 60 - 300 t Compound die |
Die manufacturing | Plastic mold | Designing Manufacturing Plate machining Mold base machining Injection molding die 60 - 300 t 000 t |
Mass production | Metal press | Bending Blanking Iron Stainless steel Titanium Plated steel plate Stainless steel material for spring Nickel Thickness Thickness Single press (80 - 200 t) Single press (200 - 500 t) Progressive press (80 - 200 t) |
Mass production | Plastic | Insert molding PVC (polyvinyl chloride) General-purpose material Engineering plastic PBT (polybutylene terephthalate) 60 - 300 t 000 t Injection molding |
Assembly/Inspection | Assembly | Industrial machinery assembly Toy and sundries assembly |
Assembly/Inspection | Repair | Industrial machinery repair Die repair |
Assembly/Inspection | Inspection | Metal press |
Parts manufacturing | Machinery part | Valve manufacturing Shaft and roller manufacturing |
Parts manufacturing | Bolt/Screw/Nut | Screw manufacturing |
