Thickness: below 0.2 mm( Mass production / Metal press ) |
Compound die( Die manufacturing / Press die ) |
Degreasing( Surface treatment / Plating/Chemical conversion treatment ) |
Small-size prototype manufacturing( Development and production of prototype/Small-scale production / Prototype processing ) |
Stainless steel( Mass production / Metal press ) |
Aluminum( Mass production / Metal press ) |
Single press (80 - 200 t)( Mass production / Metal press ) |
Company name |
株式会社高橋製作所 (Takahashiseisakusho ) |
Website URL | http://www.takahaship.co.jp |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 15 |
Annual sales | 120,000,000 JPY | EMIDAS Member Number | 74084 |
Type of manufacturing | Electronic parts / Office automation equipment / Medical equipment |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (light electrical) Drawing metal press die designing General metal press die |
Development and production of prototype/Small-scale production | Machining | General-purpose milling Machining/Handles small-scale production (order from 1 piece) Bench lathe machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Precision sheet metal machining Sheet metal protocol manufacturing Thin wall (Thickness |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Welding Bending Small-size prototype manufacturing |
Die manufacturing | Press die | Designing Manufacturing Drawing die Shaving die Progressive die Single press die Below 60 t 60 - 300 t Compound die |
Die manufacturing | Casting die | Designing Manufacturing Die-casting die |
Mass production | Metal press | Drawing Shaving Iron Stainless steel Aluminum Copper Brass Phosphor bronze Plated steel plate Stainless steel material for spring Thickness Thickness φ0.6mm - φ9.0mm Single press (below 80 t) Single press (80 - 200 t) Progressive press (35 - 80 t) |
Mass production | Mechanical processing | Tapping machining Wire machining Iron Aluminum alloy Copper alloy Casting |
Mass production | Die-casting | 125 t or less Aluminum |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Gold/Silver plating Zinc (rack) Alumite (anode oxidation) Aldine treatment (aluminum chromate) Electroless nickel (barrel) Trivalent Chromate (barrel plating) Iron Copper Brass Aluminum Stainless steel Degreasing |
Surface treatment | Coating | Powder coating Electrodeposition coating Electrostatic coating Acrylic coating Epoxy coating |
Surface treatment | Polishing/Lapping | Electropolishing |
Surface treatment | Printing and others | Silk screen printing |
Surface treatment | Heat treatment | Quenching |
Surface treatment | Barrel polishing | Barrel finishing (rotation) Barrel finishing (centrifugal) |
Surface treatment | Other surface treatment | Shot blast Glass beads blast Etching (surface treatment) |
Assembly/Inspection | Repair | Die repair |
Assembly/Inspection | Inspection | Metal press |
Parts manufacturing | Spring | Thin leaf spring Terminal spring Shaped spring Diameter |
