【精密板金】レーザー加工 ~クリーンカット実現の一貫態勢~
【アルミ溶接】 アルミ溶接対応 ノンスパッタ加工
Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
TIG welding (argon welding)( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
YAG laser machining( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
CO2 laser machining ( Development and production of prototype/Small-scale production / Blank cutting ) |
Nitrogen cutting( Development and production of prototype/Small-scale production / Blank cutting ) |
Sheet metal protocol manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Capacitator spot welding( Development and production of prototype/Small-scale production / Welding/Adhesive bonding ) |
Thin wall (Thickness: 0.5 or less)/small-size sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Laser and turret punch press processing ( Development and production of prototype/Small-scale production / Blank cutting ) |
Machining (vertical)( Development and production of prototype/Small-scale production / NC machining ) |
| Company name |
株式会社 モハラテクニカ (Moharatekunika) |
Website | www.moharatechnica.co.jp/ |
| Street address |
Gunma Japan
[See map] |
Person in charge | - |
| Capital | 10,000,000 JPY | Employees | 25 |
| Annual sales | 400,000,000 JPY | EMIDAS Member Number | 73776 |
| Large | Medium | Small |
| Development and production of prototype/Small-scale production | Machining | Stainless steel Aluminum alloy Copper alloy Iron Machining/Handles small-scale production (order from 1 piece) Titanium alloy |
| Development and production of prototype/Small-scale production | NC machining | NC milling Machining (vertical) |
| Development and production of prototype/Small-scale production | Sheet-metal processing | Chassis manufacturing Mirror surface machining Thin wall (Thickness Sheet metal protocol manufacturing Precision sheet metal machining NC set press 3-roll bending Bending (hydraulic) Deburring Coating Hair line machining Bending (servo) |
| Development and production of prototype/Small-scale production | Blank cutting | Stainless steel Thin plate (below 6 mm) Copper/Aluminum Turret punch press processing Shearing Corner shearing Laser and turret punch press processing Nitrogen cutting CO2 laser machining |
| Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing |
| Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing |
| Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding CO2 welding YAG laser machining Capacitator spot welding Stud welding Brazing TIG welding (argon welding) |
| Parts manufacturing | Machinery part | Optical parts manufacturing |
| Parts manufacturing | Electrical part | Other electrical part manufacturing |
