Most recent update: 2022-01-27
Machining/Handles small-scale production (order from 1 piece)( Development and production of prototype/Small-scale production / Machining ) |
Company name |
山本精工 株式会社 (Yamamotoseikou) |
Website URL | http://www.yamasei21.co.jp/ |
Street address |
Osaka Japan
[See map] |
Person in charge | - |
Capital | 20,000,000 JPY | Employees | 30 |
Annual sales | 600,000,000 JPY | EMIDAS Member Number | 71703 |
Type of manufacturing | Electronic parts / Industrial machinery / Machine tools |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Deep hole drilling Gear hobber Rolling Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Sintered metal Broaching Keyway milling Automatic lathe Bench lathe machining |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Sheet metal protocol manufacturing |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing CO2 laser machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Cylindrical grinding Cylindrical mirror grinding Internal grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Bending Small-size prototype manufacturing Powder sintering |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Chromium (barrel) Black chromium (barrel) Zinc (barrel) Chromate (general) Nickel (rack) Chromium (rack) Black chromium (rack) Zinc (rack) Alumite (anode oxidation) Nickel chromium (rack) Acid pickling Parkerizing (phosphate film) Electroless nickel (barrel) Electroless nickel (rack) Hard chromium (rack) |
Surface treatment | Polishing/Lapping | Electropolishing |
Surface treatment | Lap polishing | Lap polishing Lap mirror polishing |
Surface treatment | Heat treatment | Normalizing Vacuum normalizing Annealing Full annealing Vacuum annealing Quenching Vacuum quenching High frequency quenching Carburized quenching Nitridation Gas nitrocarburizing |
Surface treatment | Barrel polishing | Barrel finishing (vibration) Barrel finishing (rotation) |
Surface treatment | Other surface treatment | Teflon coating Buffing Shot blast |
Parts manufacturing | Machinery part | Valve manufacturing Crank shaft manufacturing Shaft and roller manufacturing |
Parts manufacturing | Electrical part | Other electrical part manufacturing |
