Most recent update: 2023-09-30
迅速と挑戦で破壊的イノベーションを興し金属プレス加工で技術課題を解決します。金属プレス加工、金型設計設計保全、試作、機械工、溶接加工。大正12年創業、100周年を迎えたました。
Drawing( Mass production / Metal press ) |
Company name |
株式会社 和田製作所 (Wadaseisakusho) |
Website URL | https://www.wadass.co.jp/ |
Street address |
Hiroshima Japan
[See map] |
Person in charge | - |
Capital | 18,000,000 JPY | Employees | 51 |
Annual sales | 700,000,000 JPY | EMIDAS Member Number | 71673 |
Type of manufacturing | Heavy electric machinery / Construction material / Medical equipment |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (light electrical) Drawing metal press die designing Transfer press die designing General metal press die |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Titanium Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Sheet metal protocol manufacturing Deburring Coating Bending (hydraulic) Bending (servo) |
Development and production of prototype/Small-scale production | Blank cutting | Shearing Corner shearing |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding Arc welding Robot welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Bending |
Die manufacturing | Press die | Designing Manufacturing Part processing Drawing die Bending die Blanking die Progressive die Transfer press die Single press die Press robot die Below 60 t 60 - 300 t Compound die |
Mass production | Metal press | Drawing Bending Blanking Shaving Coining Transfer press (below 80 t) Iron Stainless steel Aluminum Copper Brass Phosphor bronze Titanium Plated steel plate Stainless steel material for spring Thickness Thickness Thickness Thickness Bulge forming die Transfer press (80 - 200 t) Transfer press (200 - 500 t) Press robot (80 -200 t) Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) Progressive press (200 - 500 t) |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Wire machining Screw cutting machining Iron Stainless Aluminum alloy Copper alloy Titanium alloy Molybdenum alloy Titanium |
