Most recent update: 2022-01-20
Company name |
株式会社 ダイトウ (Daitou) |
Website URL | http://daito-higashiosaka.com/ |
Street address |
Osaka Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 36 |
Annual sales | 360,000,000 JPY | EMIDAS Member Number | 71646 |
Type of manufacturing | Construction material |
Large | Medium | Small |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Solder (barrel) Zinc (barrel) Chromate (general) Nickel (rack) Gold/Silver plating Chromium (rack) Black chromium (rack) Zinc (rack) Alumite (anode oxidation) Nickel chromium (rack) Acid pickling Aldine treatment (aluminum chromate) Parkerizing (phosphate film) Chemical conversion coating Trivalent Chromate (barrel plating) Iron Copper Brass Zinc die-cast Aluminum Stainless steel Degreasing Colored alumite Unichromate (white) Black chromate (black/green) Colored chromate (multi-color) |
Surface treatment | Coating | Air-spray coating Electrodeposition coating Electrostatic coating Urethane coating Acrylic coating Lacquer coating Epoxy coating Metal coating |
Surface treatment | Polishing/Lapping | Electropolishing Chemical polishing Buffing |
Surface treatment | Lap polishing | Lap mirror polishing |
Surface treatment | Barrel polishing | Barrel finishing (vibration) |
Surface treatment | Other surface treatment | Buffing Shot blast Sound blast Etching (surface treatment) |
Assembly/Inspection | Assembly | Construction component assembly |
