Most recent update: 2024-01-22
Company name |
株式会社工藤スプリング (Kudousupurinngu) |
Website URL | http://www.kudo-spring.co.jp |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 20,000,000 JPY | Employees | 15 |
Annual sales | 300,000,000 JPY | EMIDAS Member Number | 71033 |
Type of manufacturing | Home electrical appliances / Office automation equipment / Telecommunication equipment |
Large | Medium | Small |
Designing | Jig and tool designing | General jig designing Mass production jig designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy |
Development and production of prototype/Small-scale production | Sheet-metal processing | Can manufacturing Sheet metal protocol manufacturing |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Bending Small-size prototype manufacturing |
Mass production | Metal press | Drawing Bending Blanking Forming Multi forming Iron Stainless steel Aluminum Copper Phosphor bronze Stainless steel material for spring Thickness Thickness Diameter φ0.6mm - φ9.0mm Single press (below 80 t) Progressive press (35 - 80 t) |
Surface treatment | Heat treatment | Normalizing Annealing Straightening annealing |
Assembly/Inspection | Assembly | Precision equipment assembly |
Parts manufacturing | Spring | Thin leaf spring Terminal spring Compression coil spring Tensil coil spring Torsion spring Double torsion spring Leaf spring Shaped spring Battery spring Conical spring Formed wire spring Volute spring Spring washer Torsion spring Piano wire (carbon wire) Stainless steel Diameter Diameter |
