Magnesium alloy( Mass production / Mechanical processing ) |
Aluminum alloy( Mass production / Mechanical processing ) |
Ultra-thin( Mass production / Mechanical processing ) |
Optical parts manufacturing( Parts manufacturing / Machinery part ) |
Complex turning machining( Mass production / Mechanical processing ) |
Five-face/axes machining( Mass production / Mechanical processing ) |
Chemical conversion coating( Surface treatment / Plating/Chemical conversion treatment ) |
Magnesium alloy( Development and production of prototype/Small-scale production / Machining ) |
Combined lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Magnesium( Surface treatment / Plating/Chemical conversion treatment ) |
Company name | SunBright Co.,Ltd. | Website URL | http://www.sunbright-f.co.jp/ |
Street address |
Aizuwakamatsu Fukushima Japan
[See map] |
Person in charge | KOMORI Kazuyuki |
Telephone number | +81-242-76-1020 | Fax number | +81-242-76-1021 |
Capital | 30,000,000 JPY | Employees | 70 |
Annual sales | 1,100,000,000 JPY | EMIDAS Member Number | 70937 |
Type of manufacturing | Industrial machinery / Office automation equipment / Transportation equipment | ||
Main 3 products |
Primary clients |
PR message
<Metal cutting equipment>
We perform cutting of non-ferrous metals.
Size is up to approximately φ 200. Lot sizes range from single prototypes to mass production of up to approximately 100,000 units per month.
<Die-casting mold design and die-casting>
We design molds for aluminum and magnesium die-casting and perform die-casting.
We support various types of surface treatment including alumite, coatings, and printing.
≪Product line≫
Semiconductor fabrication equipment components Professional camera components
Computer components Pneumatic/hydraulic device components
Other precision components cutting equipment in general
Most recent update:2025-02-28
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Rolling Thread-cutting Profile milling Straightening Stainless steel High rigid material Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Nickel alloy Sintered metal Keyway milling Automatic lathe |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining NC vertical lathe Combined lathe machining |
Mass production | Mechanical processing | Machining NC turning machining Tapping machining Five-face/axes machining Complex turning machining Rolling machining Screw cutting machining Stainless Aluminum alloy Copper alloy Magnesium alloy Air chuck equipment Casting Ultra-thin High precision |
Surface treatment | Plating/Chemical conversion treatment | Alumite (anode oxidation) Parkerizing (phosphate film) Electroless nickel (barrel) Electroless nickel (rack) Chemical conversion coating Aluminum Magnesium Hard alumite |
Parts manufacturing | Machinery part | Valve manufacturing Optical parts manufacturing Shaft and roller manufacturing |
Parts manufacturing | Electrical part | Other electrical part manufacturing |
Parts manufacturing | Bolt/Screw/Nut | Screw manufacturing |
