Most recent update: 2017-09-27
Company name |
株式会社 栄光工業 (Eikoukougyou) |
Website URL | http://www.eikous.jp/ |
Street address |
kochi Japan
[See map] |
Person in charge | - |
Capital | 50,000,000 JPY | Employees | 140 |
Annual sales | 1,300,000,000 JPY | EMIDAS Member Number | 70918 |
Type of manufacturing | Industrial machinery / Furniture / Lighting equipment |
Large | Medium | Small |
Designing | Product and part designing | Gear designing |
Designing | Industrial equipment designing | Automatic machinery manufacturing Carrier machine designing Plant equipment designing Precision automatic machinery designing Industrial machinery designing Energy-saving machinery designing |
Development and production of prototype/Small-scale production | Machining | Melt cutting General-purpose milling General-purpose lathe machining Tapping Gear hobber Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Keyway milling |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling Boring milling |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing NC set press Precision sheet metal machining Sheet metal protocol manufacturing Angle machining Pipe bending Coating Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | YAG laser machining Turret punch press processing Shearing Cutting Laser and turret punch press processing Shearing (longer than 121.2 m) Corner shearing CO2 laser machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding TIG welding (argon welding) Arc welding Robot welding |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Welding Bending |
Mass production | Metal press | Drawing Bending Blanking |
Mass production | Rubber | Rubber product prototype manufacturing |
Surface treatment | Plating/Chemical conversion treatment | Chromate (general) Alumite (anode oxidation) Parkerizing (phosphate film) Baking (hydrogen embrittling) |
Surface treatment | Coating | Air-spray coating Urethane coating Acrylic coating Lacquer coating |
Surface treatment | Heat treatment | Normalizing Annealing Quenching Salt bath soft nitriding (tufftriding) |
Surface treatment | Other surface treatment | Buffing Shot blast Sound blast |
Assembly/Inspection | Assembly | Precision equipment assembly Office equipment assembly Auto parts assembly Construction component assembly Industrial machinery assembly |
Parts manufacturing | Other parts | Sign board manufacturing |
Product manufacturing | Production property | Other industrial machinery manufacturing Energy-saving equipment/Automatic instrument manufacturing Packaging machinery manufacturing |
Product manufacturing | Plant equipment manufacturing | Plant equipment manufacturing |
Product manufacturing | Furniture/Interior | Lighting equipment manufacturing |
