Most recent update: 2024-03-05
Company name |
株式会社 三豊精密 (Sannpouseimitsu) |
Website URL | http://www.sanpou-s.co.jp |
Street address |
Saitama Japan
[See map] |
Person in charge | - |
Capital | 5,000,000 JPY | Employees | 15 |
Annual sales | Unregister | EMIDAS Member Number | 70889 |
Type of manufacturing | Heavy electric machinery / Machine tools / Telecommunication equipment |
Large | Medium | Small |
Material | Nonferrous metal distribution | Plate Flat steel plate Copper and brass products Others |
Development and production of prototype/Small-scale production | Machining | Tapping Straightening Machining/Handles small-scale production (order from 1 piece) Aluminum alloy Copper alloy Automatic lathe Bench lathe machining Milling (resin) |
Development and production of prototype/Small-scale production | NC machining | NC milling |
Development and production of prototype/Small-scale production | Sheet-metal processing | NC set press Sheet metal protocol manufacturing Deburring Hair line machining Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Shearing Cutting Corner shearing |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Brazing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Punching Welding Bending |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Tin (barrel) Solder (barrel) Copper (barrel) Chromate (general) Nickel (rack) Tin (rack) Copper (rack) Gold/Silver plating Chromium (rack) Electroless nickel (barrel) Electroless nickel (rack) Copper Brass Aluminum |
Parts manufacturing | Electrical part | Other electrical part manufacturing |
