Most recent update: 2023-04-06
Company name |
株式会社 金田鉄工所 (Kanedatekkousho) |
Website URL | http://www.kaneda-t.com |
Street address |
Ishikawa Japan
[See map] |
Person in charge | - |
Capital | 35,000,000 JPY | Employees | 50 |
Annual sales | 1,100,000,000 JPY | EMIDAS Member Number | 70627 |
Type of manufacturing | Industrial machinery / Telecommunication equipment / Electronic parts |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (light electrical) Progressive die designing (auto) Drawing metal press die designing Transfer press die designing General metal press die |
Designing | Jig and tool designing | General jig designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling Tapping Machining/Handles small-scale production (order from 1 piece) Iron Aluminum alloy |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Precision sheet metal machining Sheet metal protocol manufacturing Hair line machining Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser and turret punch press processing CO2 laser machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding Arc welding Robot welding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Bending |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation Drawing die Bending die Blanking die Forming die Shaving die Progressive die Transfer press die Single press die Press robot die Below 60 t 60 - 300 t Compound die |
Mass production | Metal press | Drawing Bending Blanking Forming Multi forming Shaving Coining Transfer press (below 80 t) Iron Stainless steel Aluminum Copper Brass Phosphor bronze Plated steel plate Stainless steel material for spring Nickel Thickness Thickness Thickness φ0.6mm - φ9.0mm Transfer press (80 - 200 t) Press robot (below 80 t) Press robot (80 -200 t) Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
Assembly/Inspection | Assembly | Precision equipment assembly Auto parts assembly Construction component assembly |
Parts manufacturing | Spring | Thin leaf spring Terminal spring |
