Most recent update: 2022-12-20
Forging die designing( Designing / Mold designing ) |
Company name |
株式会社 鈴和 (Suzuwa) |
Website URL | http://www.suzuwa-press.com |
Street address |
Kanagawa Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 18 |
Annual sales | Unregister | EMIDAS Member Number | 70052 |
Type of manufacturing | Office automation equipment / Telecommunication equipment / Electronic parts |
Large | Medium | Small |
Designing | Mold designing | Forging die designing Progressive die designing (light electrical) Drawing metal press die designing General metal press die Extrusion molding die designing |
Designing | Jig and tool designing | General jig designing Mass production jig designing Automatic tool designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Machining/Handles small-scale production (order from 1 piece) Handles microfabrication |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Form grinding Jig grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Bending Small-size prototype manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining Drawing die Bending die Blanking die Forming die Shaving die Progressive die Single press die Press robot die Below 60 t 60 - 300 t Compound die |
Die manufacturing | Spring mold | Designing Manufacturing Spring die part processing Leaf spring die |
Die manufacturing | Forging die | Designing Manufacturing Forging die part processing NC data creation Cold forging die Press forging die |
Mass production | Metal press | Drawing Bending Blanking Shaving Coining Iron Stainless steel Aluminum Copper Brass Phosphor bronze Titanium Plated steel plate Stainless steel material for spring Nickel Thickness Thickness Diameter Combined press-joining Beryllium copper Single press (below 80 t) Single press (80 - 200 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
Mass production | Forging | Cold forging Press forging Iron Aluminum Brass Others Below 500 g |
Surface treatment | Barrel polishing | Barrel finishing (rotation) |
Parts manufacturing | Spring | Thin leaf spring Terminal spring Stainless steel Copper alloy Diameter Diameter |
