Most recent update: 2023-04-11
Progressive die designing (light electrical)( Designing / Mold designing ) |
Manufacturing( Die manufacturing / Press die ) |
Terminal spring( Parts manufacturing / Spring ) |
Company name |
竹伸精密 株式会社 (Chikushinnseimitsu) |
Website URL | http://www.take-group.co.jp/ |
Street address |
Kyoto Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 23 |
Annual sales | Unregister | EMIDAS Member Number | 70041 |
Type of manufacturing | Audio-video equipment / Electronic parts |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (light electrical) Progressive die designing (auto) Drawing metal press die designing Transfer press die designing General metal press die |
Development and production of prototype/Small-scale production | Machining | General-purpose milling Tapping Spinning Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Nickel alloy |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Sheet metal protocol manufacturing Deburring |
Development and production of prototype/Small-scale production | Blank cutting | Shearing Cutting |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Form grinding Cylindrical grinding Profile grinding Jig boring Jig grinding Internal grinding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Bending |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation Drawing die Bending die Blanking die Forming die Fine blanking die Roll forming die Shaving die Progressive die Transfer press die Single press die Press robot die Below 60 t 60 - 300 t Compound die |
Die manufacturing | Forging die | Cold forging die |
Mass production | Metal press | Drawing Bending Blanking Forming Fine blanking Roll forming Shaving Coining Transfer press (below 80 t) Iron Stainless steel Aluminum Copper Brass Phosphor bronze Titanium Plated steel plate Stainless steel material for spring Nickel Thickness Thickness Press robot (below 80 t) Progressive press (35 - 80 t) |
Surface treatment | Printing and others | Engraving |
Parts manufacturing | Spring | Thin leaf spring Terminal spring |
