Most recent update: 2017-12-05
Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Company name |
株式会社 南光 (Nannkou) |
Website URL | http://www.nanko.co.jp/ |
Street address |
Kagoshima Japan
[See map] |
Person in charge | - |
Capital | 100,000,000 JPY | Employees | 220 |
Annual sales | Unregister | EMIDAS Member Number | 69332 |
Type of manufacturing | Construction material / Jigs and tools / Industrial machinery |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (auto) Transfer press die designing General metal press die NC data creation (press) |
Designing | Jig and tool designing | General jig designing |
Development and production of prototype/Small-scale production | Machining | Tapping Thread-cutting Spinning Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Ceramic Sintered metal Keyway milling |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Five-face machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Air-conditioning equipment manufacturing Kitchen unit manufacturing Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Pipe bending Deburring Coating Hair line machining 3-roll bending 3-roll bending (2 m or longer) Bending (hydraulic) 3D pipe machining Can manufacturing (over 5 m) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser and turret punch press processing Laser processing (longer than 121.2 m) Shearing (longer than 121.2 m) Corner shearing CO2 laser machining Nitrogen cutting Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum Ceramic Acrylic 3D laser machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Cylindrical grinding Internal grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding Brazing Stud welding Semiconductor laser welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Drawing die Bending die Blanking die Progressive die Transfer press die Single press die 60 - 300 t Over 300 t |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Aluminum Thickness Thickness Transfer press (80 - 200 t) Transfer press (over 500 t) Single press (80 - 200 t) Single press (200 - 500 t) Single press (500 t and over) Progressive press (35 - 80 t) Progressive press (80 - 200 t) Progressive press (200 - 500 t) Progressive press (over 500 t) |
Surface treatment | Coating | Melamine coating Urethane coating Acrylic coating Lacquer coating |
Assembly/Inspection | Assembly | Construction component assembly Industrial machinery assembly |
Assembly/Inspection | Repair | Construction repair Die repair |
Parts manufacturing | Machinery part | Vacuum components manufacturing |
Parts manufacturing | Other parts | Sign board manufacturing |
Product manufacturing | Production property | Other industrial machinery manufacturing Electrical machinery and apparatus manufacturing Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing Environmental equipment manufacturing |
Product manufacturing | Plant equipment manufacturing | Plant equipment manufacturing Marine vessel equipment manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Construction and civil engineering material manufacturing |
