Most recent update: 2024-02-19
Single press (80 - 200 t)( Mass production / Metal press ) |
Company name |
久語工業 株式会社 (Kugokougyou) |
Website URL | |
Street address |
Hyogo Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 16 |
Annual sales | Unregister | EMIDAS Member Number | 69310 |
Type of manufacturing | Home electrical appliances / Electrical component for transportation equipment / Lighting equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | Spinning |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining Drawing die Bending die Blanking die Single press die Below 60 t 60 - 300 t Compound die |
Mass production | Metal press | Drawing Bending Blanking Stainless steel Aluminum Copper Brass Phosphor bronze Thickness Thickness Thickness Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Tin (barrel) Copper (barrel) Chromium (barrel) Black chromium (barrel) Zinc (barrel) Chromate (general) Nickel (rack) Copper (rack) Gold/Silver plating Chromium (rack) Zinc (rack) Nickel chromium (rack) Electroless nickel (barrel) Electroless nickel (rack) Trivalent Chromate (barrel plating) Hard chromium (rack) |
Surface treatment | Coating | Powder coating Electrostatic coating |
