Micro hole machining( Development and production of prototype/Small-scale production / Electrical discharge machine ) |
Handles microfabrication( Development and production of prototype/Small-scale production / Machining ) |
Five-face/axes machining( Mass production / Mechanical processing ) |
Simultaneous 5-axis machining( Development and production of prototype/Small-scale production / Machining ) |
3D modeling( Die manufacturing / Press die ) |
Jig and tool manufacturing( Development and production of prototype/Small-scale production / Jig manufacturing ) |
Air chuck equipment( Development and production of prototype/Small-scale production / Machining ) |
Company name |
株式会社 ユーコウパーツ (Yu-koupa-tsu) |
Website URL | http://www.yuko-parts.co.jp/ |
Street address |
Chiba Japan
[See map] |
Person in charge | - |
Capital | 20,000,000 JPY | Employees | 25 |
Annual sales | 350,000,000 JPY | EMIDAS Member Number | 69169 |
Type of manufacturing | Electronic parts / Jigs and tools / Industrial machinery |
Large | Medium | Small |
Designing | Jig and tool designing | General jig designing Mass production jig designing General-purpose jig designing |
Material | Steel component distribution | Stainless steel Stainless steel pipe |
Material | Specialized material distribution | Phosphor bronze Molybdenum alloy |
Material | Nonferrous metal distribution | Flat steel plate Steel (round) bar Copper and brass products Pipe material Others |
Material | Plastic material distribution | POM (polyoxymethylene) |
Development and production of prototype/Small-scale production | Machining | Melt cutting General-purpose milling General-purpose lathe machining Tapping Deep hole drilling Gear hobber Thread-cutting Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Titanium alloy Ceramic Machining (resin) Sintered metal Keyway milling Automatic lathe Shaper machining Simultaneous 5-axis machining Milling (resin) Air chuck equipment Lathe machining (resin) Handles microfabrication Handles microfabrication Titanium |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) 5-face/5-axis machining Machining (horizontal) Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Chassis manufacturing Deburring Coating Bending (hydraulic) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | YAG laser machining Turret punch press processing Shearing Cutting Water jet cutter machining CO2 laser machining Thin plate (below 6 mm) Stainless steel Copper/Aluminum Acrylic Precision cutting |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding Plane grinding Form grinding Cylindrical grinding Profile grinding Jig boring Jig grinding Internal grinding Centerless grinding Thread grinding Gear grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | TIG welding (argon welding) Brazing YAG laser machining |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Small-size prototype manufacturing Aluminum die-casting |
Die manufacturing | Press die | Manufacturing Part processing Plate machining Die set machining NC data creation 3D modeling |
Die manufacturing | Plastic mold | Manufacturing Part processing Plate machining Mold base machining NC data creation 3D modeling Core and cavity machining |
Mass production | Mechanical processing | Machining NC milling machining Five-face/axes machining Micro-hole machining Iron Aluminum alloy Automatic screw machining Air chuck equipment Fine particle material accepted |
Surface treatment | Plating/Chemical conversion treatment | Chromate (general) Nickel (rack) Chromium (rack) Black chromium (rack) Zinc (rack) Alumite (anode oxidation) Electroless nickel (rack) Iron Copper Brass Aluminum Stainless steel Degreasing Black oxide finish Hard alumite Unichromate (white) Black chromate (black/green) |
Surface treatment | Polishing/Lapping | Electropolishing |
Surface treatment | Heat treatment | Annealing Salt bath quenching Vacuum quenching High frequency quenching Carburized quenching Salt bath soft nitriding (tufftriding) Nitridation Gas nitrocarburizing |
Surface treatment | Other surface treatment | Other physical vapor deposition methods (PVD) Coating Teflon coating Shot peening/WPC Buffing Glass beads blast |
Assembly/Inspection | Repair | Die repair |
Assembly/Inspection | Inspection | Measuring |
Parts manufacturing | Machinery part | Shaft and roller manufacturing |
Parts manufacturing | Bolt/Screw/Nut | Screw manufacturing |
