Most recent update: 2023-09-02
Company name |
株式会社 ダイセー (Daise-) |
Website URL | https://www.kdaise.co.jp/ |
Street address |
Ishikawa Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 30 |
Annual sales | 400,000,000 JPY | EMIDAS Member Number | 68899 |
Type of manufacturing | Machine tools / Industrial machinery / Medical equipment |
Large | Medium | Small |
Designing | Electrical planning | Electrical machinery and apparatus designing Software designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Titanium alloy |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing NC set press Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Angle machining Pipe bending Deburring Coating Mirror surface machining Hair line machining 3-roll bending Bending (hydraulic) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser processing (longer than 121.2 m) Shearing (longer than 121.2 m) Corner shearing CO2 laser machining Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Plasma welding Arc welding Brazing Stud welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Aluminum Copper Brass Phosphor bronze Titanium Plated steel plate Stainless steel material for spring Thickness Thickness Thickness Thickness φ0.6mm - φ9.0mm Diameter Single press (below 80 t) |
Surface treatment | Coating | Air-spray coating Lacquer coating Metal coating |
Surface treatment | Polishing/Lapping | Electropolishing Chemical polishing Tool polishing |
Surface treatment | Lap polishing | Lap mirror polishing |
Surface treatment | Barrel polishing | Barrel finishing (rotation) |
Assembly/Inspection | Assembly | Industrial machinery assembly |
Assembly/Inspection | Inspection | Metal press Spring |
Parts manufacturing | Spring | Thin leaf spring Compression coil spring Tensil coil spring Leaf spring Piano wire (carbon wire) Stainless steel Diameter |
Product manufacturing | Production property | Machine tool manufacturing Other industrial machinery manufacturing Electrical machinery and apparatus manufacturing Energy-saving equipment/Automatic instrument manufacturing Carrier machine manufacturing Packaging machinery manufacturing Industrial robot manufacturing Environmental equipment manufacturing |
Product manufacturing | Plant equipment manufacturing | Plant equipment manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Construction and civil engineering material manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing |
Product manufacturing | Others | Welfare equipment manufacturing |
