Most recent update: 2024-04-18
Aluminum alloy( Mass production / Mechanical processing ) |
Optical parts manufacturing( Parts manufacturing / Machinery part ) |
Combined lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
Company name |
株式会社 オザキ (Ozaki) |
Website URL | http://www.kk-ozaki.jp |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 20,000,000 JPY | Employees | 30 |
Annual sales | Unregister | EMIDAS Member Number | 68708 |
Type of manufacturing | Industrial machinery / Audio-video equipment / Medical equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling Tapping Gear hobber Thread-cutting Tube drawing Iron Aluminum alloy Copper alloy Broaching Keyway milling Automatic lathe Bench lathe machining Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Boring milling Combined lathe machining Machining (horizontal) |
Development and production of prototype/Small-scale production | Grinding processing | Cylindrical mirror grinding |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Complex turning machining Gear cutting machining Screw cutting machining Aluminum alloy Copper alloy Broaching machining |
Mass production | Die-casting | Aluminum |
Mass production | Forging | Cold forging Aluminum Brass Below 500 g |
Mass production | Casting | Aluminum alloy 500 g and below |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Chromium (barrel) Nickel (rack) Chromium (rack) Alumite (anode oxidation) Nickel chromium (rack) Electroless nickel (barrel) Electroless nickel (rack) Chemical conversion coating Copper Brass Aluminum Degreasing Black oxide finish Colored alumite Hard alumite Nickel (hoop) |
Surface treatment | Heat treatment | Stress relief annealing (SR treatment) Straightening annealing Quenching |
Surface treatment | Other surface treatment | Shot blast Sound blast Glass beads blast Etching (surface treatment) |
Assembly/Inspection | Inspection | Measuring |
Parts manufacturing | Machinery part | Gear manufacturing Valve manufacturing Bearing manufacturing Connection parts manufacturing Optical parts manufacturing |
Parts manufacturing | Electrical part | Connector manufacturing |
Product manufacturing | Production property | Electrical machinery and apparatus manufacturing Optical products manufacturing Hydraulic pressure equipment manufacturing Fluid equipment manufacturing Industrial robot manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing |
Product manufacturing | Household commodity | Office equipment manufacturing |
Product manufacturing | Others | Telecommunication equipment manufacturing |
