Most recent update: 2024-03-05
Company name |
オーエムアイ株式会社 (O-emuai) |
Website URL | http://www.perfect-omi.co.jp |
Street address |
Saitama Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 40 |
Annual sales | 700,000,000 JPY | EMIDAS Member Number | 68654 |
Type of manufacturing | Electronic parts / Kitchen / Medical equipment |
Large | Medium | Small |
Designing | Product and part designing | Medical equipment designing |
Designing | Jig and tool designing | General jig designing |
Designing | Electrical planning | Electrical machinery and apparatus designing PCB designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Deep hole drilling Thread-cutting Spinning Machining/Handles small-scale production (order from 1 piece) Keyway milling |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Boring milling |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining NC set press Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Angle machining Pipe bending Deburring Coating Mirror surface machining Hair line machining Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | YAG laser machining Turret punch press processing Shearing Cutting Corner shearing CO2 laser machining |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Plasma welding Arc welding Robot welding Brazing Stud welding |
Development and production of prototype/Small-scale production | Jig manufacturing | Welding jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing Porous plastic prototype |
Die manufacturing | Press die | Designing Manufacturing Part processing |
Die manufacturing | Plastic mold | Designing Manufacturing Part processing Injection molding die Extrusion molding die |
Die manufacturing | Rubber mold | Designing Part processing |
Die manufacturing | Spring mold | Manufacturing Spring die part processing |
Mass production | Metal press | Drawing Bending Blanking |
Mass production | Rubber | Rubber product prototype manufacturing Press stamping |
Assembly/Inspection | Assembly | Precision equipment assembly |
Parts manufacturing | Electric board and electronic part | Electronic parts assembly and wiring |
Parts manufacturing | Spring | Compression coil spring Tensil coil spring Leaf spring |
Parts manufacturing | Other parts | Sign board manufacturing |
Product manufacturing | Production property | Other industrial machinery manufacturing Electrical machinery and apparatus manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Construction and civil engineering material manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing |
Product manufacturing | Others | Welfare equipment manufacturing |
