Most recent update: 2016-08-02
5-face/5-axis machining( Development and production of prototype/Small-scale production / NC machining ) |
Company name |
株式会社ヤマダ精機 (Yamadaseiki) |
Website URL | http://yamadaseiki.co.jp |
Street address |
Saitama Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 30 |
Annual sales | Unregister | EMIDAS Member Number | 68603 |
Type of manufacturing | Transportation equipment / Heavy electric machinery / Industrial machinery |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Deep hole drilling Gear hobber Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Nickel alloy Molybdenum alloy Sintered metal Sintered metal Simultaneous 5-axis machining Casting Honing |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) Additional-axis machining NC milling NC lathe machining 5-face/5-axis machining Five-face machining Boring milling NC facing Machining (horizontal) Handles 3D processing |
Development and production of prototype/Small-scale production | Grinding processing | NC cylindrical grinding Plane grinding Form grinding Cylindrical grinding Internal grinding Centerless grinding Gear grinding NC internal grinding Rotary grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | TIG welding (argon welding) Arc welding Brazing |
Development and production of prototype/Small-scale production | Prototype processing | Small-size prototype manufacturing |
Development and production of prototype/Small-scale production | Casting | Gravity casting Sand casting cast iron Ductile cast iron Cast steel Aluminum alloy |
Surface treatment | Plating/Chemical conversion treatment | Chromate (general) Nickel (rack) Copper (rack) Chromium (rack) Black chromium (rack) Zinc (rack) Alumite (anode oxidation) Nickel chromium (rack) Aldine treatment (aluminum chromate) Parkerizing (phosphate film) Electroless nickel (rack) Chemical conversion coating Trivalent Chromate (barrel plating) Iron Aluminum Other anti-rust treatments Hard chromium (rack) Magnesium Black oxide finish Colored alumite Hard alumite Unichromate (white) Black chromate (black/green) Colored chromate (multi-color) |
Surface treatment | Coating | Electrodeposition coating Metal coating |
Surface treatment | Polishing/Lapping | Electropolishing Chemical polishing Buffing |
Surface treatment | Heat treatment | Normalizing Annealing Stress relief annealing (SR treatment) Quenching High frequency quenching Solution heat treatment Sub-zero treatment Carburized quenching Nitridation Gas nitrocarburizing |
Surface treatment | Other surface treatment | Spraying Resin impregnation Carbide Dispersion/TD Shot peening/WPC Buffing Shot blast Sound blast Plasma spray |
