Most recent update: 2018-08-03
Company name |
阪本巧作 株式会社 (Sakamotokousakukabushikigaisha) |
Website URL | http://www.alumi-factory.jp |
Street address |
Osaka Japan
[See map] |
Person in charge | - |
Capital | 3,000,000 JPY | Employees | 5 |
Annual sales | Unregister | EMIDAS Member Number | 68460 |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Rolling Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Keyway milling Shaper machining Router machining Titanium |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Sheet metal protocol manufacturing Deburring Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Cutting Water jet cutter machining CO2 laser machining Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | TIG welding (argon welding) |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending |
Surface treatment | Barrel polishing | Barrel finishing (vibration) |
Assembly/Inspection | Assembly | Auto parts assembly Industrial machinery assembly |
Parts manufacturing | Machinery part | Valve manufacturing Shaft and roller manufacturing |
