Most recent update: 2023-03-22
Company name |
有限会社 甘利製作所 玉川工場 (Amariseisakusho tamagawakoujou) |
Website URL | |
Street address |
Kanagawa Japan
[See map] |
Person in charge | - |
Capital | 3,000,000 JPY | Employees | 10 |
Annual sales | 200,000,000 JPY | EMIDAS Member Number | 67118 |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Gear hobber Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Titanium alloy Machining (resin) Keyway milling Bench lathe machining |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Cylindrical grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing |
Surface treatment | Plating/Chemical conversion treatment | Chromate (general) Gold/Silver plating Chromium (rack) Black chromium (rack) Zinc (rack) Alumite (anode oxidation) Acid pickling Aldine treatment (aluminum chromate) Parkerizing (phosphate film) Electroless copper (rack) Electroless nickel (rack) Iron Copper Brass Aluminum Stainless steel |
Surface treatment | Polishing/Lapping | Electropolishing Chemical polishing |
Surface treatment | Lap polishing | Lap polishing |
Surface treatment | Heat treatment | Normalizing Vacuum normalizing Annealing Full annealing Straightening annealing Vacuum annealing Quenching Vacuum quenching High frequency quenching Solution heat treatment Carburized quenching Nitridation |
Surface treatment | Other surface treatment | Teflon coating Buffing Shot blast Sound blast Glass beads blast |
Assembly/Inspection | Assembly | Precision equipment assembly Industrial machinery assembly |
