Cast-iron ( Mass production / Casting ) |
Machining/Handles small-scale production (order from 1 piece)( Development and production of prototype/Small-scale production / Machining ) |
Ductile cast iron( Mass production / Casting ) |
Casting( Mass production / Mechanical processing ) |
Casting( Designing / Simulation ) |
Data creation (3D scan)( Designing / Data creation (3D scan) ) |
NC lathe machining( Development and production of prototype/Small-scale production / NC machining ) |
5-face/5-axis machining( Development and production of prototype/Small-scale production / NC machining ) |
Sand casting ( Mass production / Casting ) |
Annealing( Surface treatment / Heat treatment ) |
Company name | Tominaga Co.,Ltd. | Website URL | http://www.ftm-tominaga.co.jp/ |
Street address |
Kochi City kochi Japan
[See map] |
Person in charge | 島田 誠 |
Telephone number | Log in to display | Fax number | Log in to display |
Capital | 50,000,000 JPY | Employees | 99 |
Annual sales | 1,500,000,000 JPY | EMIDAS Member Number | 66424 |
Type of manufacturing | Machine tools / Industrial machinery / Transportation equipment | ||
Main 3 products |
PR message
We have an integrated production system for pig iron casting products.
We are able to provide a wide range of services such as wood mold production, casting, heat treatment, painting, machining (NC lathe machining, turning machining, machining), etc.
We can provide a wide range of services such as
We handle gray cast iron (materials FC200 to FC350) and ductile cast iron (materials FCD400 to FCD700).
We have a wide range of products for industrial machinery parts, ship machinery parts, construction machinery, machine tools, public facilities, etc.
We strive to create optimal castings by making full use of casting simulation.
We propose low-cost, high-quality manufacturing methods that meet our customers' needs.
We also use a 3D scanner to quickly and accurately measure dimensions, and we are able to convert errors between drawings and the actual product into data.
We guarantee the accuracy of our products.
Product weight: 30 kg to 1.5 t. Other weight can be handled by our partner companies.
<Main delivery record
Textile machinery industry (circular knitting looms, weft knitting looms, synthetic fiber spinning machines, etc.)
Injection molding machine industry (plastic injection molding machines, die-casting machines, etc.)
Industrial machinery industry (gas turbine generators, large cranes for ships, dredging machinery, etc.)
Machine tool industry (NC multi-tasking lathes, NC lathes, etc.)
Shipbuilding industry (stern shaft parts, parts for printing machines, valve parts for hulls, etc.)
<Casting capacity
Melting capacity MAX 500t/month
Production capacity 400t
Materials available Grey cast iron (FC200-350)
Ductile cast iron (FCD 450-600)
FC:FCD ratio FC 60%:FCD 40
Casting weight 1Kg to 2,500Kg
Maximum frame size 2,200mm x 2,200mm
<Machining capacity
Various machining is possible with our lathes and large machining centers.
Lathe machining Φ2,000mm
Machining 3,700mm × 2,000mm × 600mm
Machining accuracy: 50μ〜.
Material 90% cast iron, 10% iron
<Inspection capability
Inspection of internal defects using ultrasonic waves
→Internal flaws are determined by ultrasonic flaw testing method.
Inspection of external defects by color check
→The penetrant flaw test (color check) is used to determine whether surface defects on the casting surface and machined surface are acceptable or not.
Analysis and inspection of composition, flow, and solidification using various equipment.
→Daily control of each material component using emission spectrophotometers to maintain component quality.
→Use casting simulation software to predict in advance the flow of hot metal and the solidification process.
→The casting simulation software is used to predict the flow and solidification process in advance to reduce the risk of defects and to make improvements.
Quick and easy-to-understand dimensional measurement by 3D scanner
→Æ Perform 3D visualized dimensional shape inspection by comparing nominal drawing CAD data and scanned mesh data.
<Qualified Personnel
Casting Meister (Germany) 1
Casting Tehinica (Germany) 1 person
Casting Engineer (certified by the Japan Foundry Association): 4
Iron Casting Casting Technician 1st Class: 13
Iron Casting 2nd Class Casting Technician 12
Machining center 1st class technician: 4
Machining center 2nd class technician: 5
UT (ultrasonic flaw detection) technician level 2: 3
PT (Penetrant Testing) technician level 2: 2
Level 1 technician for metal materials mechanical testing 1 person
(as of November 2019)
Most recent update:2023-03-08
Large | Medium | Small |
Designing | Simulation | 3D modeling Casting |
Designing | Data creation (3D scan) | Data creation (3D scan) |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Straightening Machining/Handles small-scale production (order from 1 piece) Iron Automatic lathe Casting |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining NC vertical lathe Machining (horizontal) |
Development and production of prototype/Small-scale production | Casting | cast iron Ductile cast iron 5kg or more |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Five-face/axes machining Screw cutting machining Iron Casting |
Mass production | Casting | Shell moulding Sand casting Cast-iron Ductile cast iron 5 kg and over |
Surface treatment | Heat treatment | Annealing |
Assembly/Inspection | Assembly | Industrial machinery assembly |
Assembly/Inspection | Inspection | Casting |
