Most recent update: 2023-01-06
Company name |
株式会社 タイヘイテクノサービス (Taiheitekunosa-bisu) |
Website URL | http://www.taihei-s.com |
Street address |
Kanagawa Japan
[See map] |
Person in charge | - |
Capital | 15,000,000 JPY | Employees | 20 |
Annual sales | Unregister | EMIDAS Member Number | 66409 |
Type of manufacturing | Jigs and tools / Industrial machinery / Transportation equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Machining/Handles small-scale production (order from 1 piece) Iron Nickel alloy Sintered metal Automatic lathe |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Small-size prototype manufacturing Powder sintering |
Mass production | Powder metallurgy | Ceramic Metal High rigidity Below 500 g 500 g - 5 kg |
Mass production | Casting | Shell moulding Lost-wax Gravity casting Centrifugal casting Sand casting Cast-iron Ductile cast iron Cast steel Aluminum alloy Zinc alloy 500 g and below Over 500 g and less than 5 kg 5 kg and over |
Surface treatment | Plating/Chemical conversion treatment | Electroless nickel (barrel) Electroless nickel (rack) Iron Brass Zinc die-cast Hard chromium (rack) |
Surface treatment | Heat treatment | Nitridation |
Surface treatment | Other surface treatment | Other physical vapor deposition methods (PVD) CVD (chemical vapor deposition) High-speed frame spraying (HVOF) Spraying Resin impregnation Teflon coating Shot peening/WPC |
