Most recent update: 2021-08-27
General metal press die( Designing / Mold designing ) |
Company name |
蒲谷工業株式会社 (Kabayakougyou) |
Website URL | https://kabaya.business.site/ |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 8 |
Annual sales | 120,000,000 JPY | EMIDAS Member Number | 66251 |
Type of manufacturing | Industrial machinery / Leisure goods / Machine tools |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (light electrical) Progressive die designing (auto) Drawing metal press die designing General metal press die NC data creation (press) |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing NC set press Chassis manufacturing Sheet metal protocol manufacturing Angle machining Deburring Coating Mirror surface machining Hair line machining 3-roll bending Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser processing (longer than 121.2 m) CO2 laser machining Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Brazing Stud welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation Drawing die Bending die Blanking die Progressive die Single press die Press robot die Below 60 t Compound die |
Mass production | Metal press | Drawing Bending Blanking Coining Iron Stainless steel Aluminum Copper Brass Phosphor bronze Titanium Plated steel plate Stainless steel material for spring Thickness Press robot (below 80 t) Single press (below 80 t) Progressive press (35 - 80 t) |
Parts manufacturing | Spring | Thin leaf spring Terminal spring Stainless steel Copper alloy Diameter Diameter |
Product manufacturing | Production property | Optical products manufacturing Information equipment manufacturing Monitoring device manufacturing Environmental equipment manufacturing |
Product manufacturing | Plant equipment manufacturing | Marine vessel equipment manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing |
Product manufacturing | Household commodity | Office equipment manufacturing |
Product manufacturing | Furniture/Interior | Lighting equipment manufacturing |
Product manufacturing | Others | Welfare equipment manufacturing Transportation equipment manufacturing Telecommunication equipment manufacturing |
