Most recent update: 2017-05-17
Progressive die designing (auto)( Designing / Mold designing ) |
Company name |
株式会社 ワカエ (Wakae) |
Website URL | http://www.wakae1960.net/ |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 5 |
Annual sales | 120,000,000 JPY | EMIDAS Member Number | 66113 |
Type of manufacturing | Telecommunication equipment / Electronic parts / Jigs and tools |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (light electrical) Progressive die designing (auto) Drawing metal press die designing General metal press die |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Copper alloy Titanium alloy |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining |
Development and production of prototype/Small-scale production | Blank cutting | CO2 laser machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Punching Bending |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining Drawing die Bending die Blanking die Progressive die Single press die |
Die manufacturing | Plastic mold | Designing Manufacturing Part processing Plate machining Mold base machining Insert molding die Outsert molding die |
Mass production | Metal press | Drawing Bending Blanking Forming Iron Stainless steel Aluminum Copper Brass Phosphor bronze Titanium Plated steel plate Thickness Thickness |
Mass production | Plastic | Insert molding Outsert molding Below 60 t 60 - 300 t |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Tin (barrel) Solder (barrel) Chromium (barrel) Black chromium (barrel) Zinc (barrel) Chromate (general) Nickel (rack) Tin (rack) Gold/Silver plating Black chromium (rack) Zinc (rack) Electroless nickel (barrel) Electroless nickel (rack) Degreasing Unichromate (white) Colored chromate (multi-color) |
Surface treatment | Heat treatment | Annealing Quenching Vacuum quenching |
Surface treatment | Barrel polishing | Barrel finishing (rotation) |
Assembly/Inspection | Assembly | Precision equipment assembly Auto parts assembly |
Assembly/Inspection | Inspection | Metal press Plastic |
Parts manufacturing | Electrical part | Connector manufacturing |
Parts manufacturing | Spring | Thin leaf spring Terminal spring |
