Most recent update: 2017-09-28
Company name |
株式会社 オースズ (O-suzu) |
Website URL | http://www.ohsuzu.co.jp |
Street address |
Kanagawa Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 50 |
Annual sales | Unregister | EMIDAS Member Number | 65968 |
Type of manufacturing | Home electrical appliances / Transportation equipment / Jigs and tools |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (light electrical) Progressive die designing (auto) Drawing metal press die designing General metal press die NC data creation (press) |
Designing | Jig and tool designing | General jig designing Mass production jig designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Nickel alloy |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC lathe machining |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Precision sheet metal machining Sheet metal protocol manufacturing Angle machining Deburring Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Corner shearing |
Development and production of prototype/Small-scale production | Grinding processing | Jig grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Mass production jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Bending |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation Drawing die Bending die Blanking die Fine blanking die Progressive die Transfer press die Single press die Below 60 t 60 - 300 t |
Die manufacturing | Spring mold | Designing Manufacturing Spring die part processing Leaf spring die |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Aluminum Copper Phosphor bronze Stainless steel material for spring Nickel Thickness Thickness Single press (below 80 t) Single press (80 - 200 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) Progressive press (200 - 500 t) |
Surface treatment | Plating/Chemical conversion treatment | Chromate (general) Aldine treatment (aluminum chromate) |
Surface treatment | Coating | Metal coating |
Surface treatment | Barrel polishing | Barrel finishing (rotation) |
Assembly/Inspection | Assembly | Precision equipment assembly Auto parts assembly |
Assembly/Inspection | Inspection | Metal press |
Parts manufacturing | Spring | Terminal spring |
