伊藤彰産業と2020年にM&Aでグループになった東海空圧機器はどちらも業歴40年以上。材料や加工は伊藤彰産業で、機械の設計、製造、メンテナンスは東海空圧機器が行う事で弊社の提案力が向上しました。
Steel (round) bar( Material / Steel component distribution ) |
Machining/Handles small-scale production (order from 1 piece)( Development and production of prototype/Small-scale production / Machining ) |
Flat steel plate( Material / Nonferrous metal distribution ) |
Can manufacturing (over 5 m)( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Jig and tool manufacturing( Development and production of prototype/Small-scale production / Jig manufacturing ) |
Steel castings( Material / Steel component distribution ) |
Bending( Development and production of prototype/Small-scale production / Prototype processing ) |
Company name |
株式会社 伊藤彰産業 (Itouakirasanngyou) |
Website URL | http://www.itoakirasangyo.co.jp/ |
Street address |
Aichi Japan
[See map] |
Person in charge | - |
Capital | 48,000,000 JPY | Employees | 23 |
Annual sales | 630,000,000 JPY | EMIDAS Member Number | 65256 |
Type of manufacturing | Jigs and tools / Measuring machinery / Industrial machinery |
Large | Medium | Small |
Designing | Product and part designing | Measurement/testing device designing |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing Automatic tool designing General-purpose jig designing |
Designing | Test | Specimen processing |
Designing | Industrial equipment designing | Automatic machinery manufacturing Carrier machine designing Precision automatic machinery designing Industrial machinery designing Food industry machinery designing Energy-saving machinery designing |
Material | Steel component distribution | Pickled steel plate Heavy plate Stainless steel Perforated metal Expanded metal Hot-rolled steel plate Cold-rolled steel plate Hot-dipped steel plate Chequered plate Tool steel Free-machining steel Other steel plates and straps Shaped steel Flat steel plate Steel (round) bar Railroad track Other shaped steel bars Seamless steel pipe Welded steel pipe Rectangular steel pipe Drawn steel pipe Steel forgings Steel castings Other steel pipes |
Material | Specialized material distribution | Phosphor bronze |
Material | Nonferrous metal distribution | Plate Flat steel plate Steel (round) bar |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Planer machining Deep hole drilling Gear hobber Thread-cutting Straightening Spinning Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Magnesium alloy Titanium alloy Nickel alloy Molybdenum alloy Ceramic Machining (resin) Sintered metal Sintered metal Keyway milling Milling (resin) Lathe machining (resin) Casting Honing Titanium Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Five-face machining Boring milling NC vertical lathe Combined lathe machining Machining (horizontal) Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Bending (over 3.0 m) Angle machining Pipe bending Bending (hydraulic) Can manufacturing (over 5 m) |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Plane grinding Cylindrical grinding Jig boring Jig grinding Internal grinding Centerless grinding Gear grinding NC internal grinding Rotary grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding TIG welding (argon welding) Arc welding Brazing |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing Jig and tool manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Welding Bending Aluminum die-casting Prototype/Small-lot molding prototype mold |
Development and production of prototype/Small-scale production | Casting | Lost wax Sand casting cast iron Ductile cast iron Cast steel Aluminum alloy Copper alloy |
Die manufacturing | Press die | Part processing Plate machining Blanking die |
Surface treatment | Plating/Chemical conversion treatment | Iron |
