Most recent update: 2023-12-18
Progressive die( Die manufacturing / Press die ) |
Thickness: below 0.2 mm( Mass production / Metal press ) |
Company name |
株式会社 エヌビー精密 (Enubi-seimitsu) |
Website URL | http://www.nb-sj.co.jp |
Street address |
Shizuoka Japan
[See map] |
Person in charge | - |
Capital | 45,000,000 JPY | Employees | 30 |
Annual sales | EMIDAS Member Number | 65076 | |
Type of manufacturing | Telecommunication equipment / Electronic parts / Medical equipment |
Large | Medium | Small |
Designing | Mold designing | Progressive die designing (light electrical) Progressive die designing (auto) Drawing metal press die designing General metal press die |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel High rigid material Aluminum alloy Copper alloy Titanium alloy Nickel alloy Bench lathe machining Titanium |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Form grinding Cylindrical grinding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Bending Small-size prototype manufacturing Chassis prototype manufacturing |
Die manufacturing | Press die | Designing Manufacturing Part processing Plate machining Die set machining NC data creation Drawing die Bending die Blanking die Shaving die Progressive die Single press die Below 60 t 60 - 300 t Compound die |
Mass production | Metal press | Drawing Bending Blanking Shaving Coining Iron Stainless steel Aluminum Copper Brass Phosphor bronze Titanium Plated steel plate Stainless steel material for spring Thickness Thickness Thickness Diameter φ0.6mm - φ9.0mm Diameter Beryllium copper Single press (below 80 t) Single press (80 - 200 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
