Most recent update: 2023-09-04
Progressive press (80 - 200 t)( Mass production / Metal press ) |
Construction and civil engineering material manufacturing( Product manufacturing / Construction and civil engineering machinery manufacturing ) |
Shaped spring( Parts manufacturing / Spring ) |
Company name |
株式会社 カシワセ (Kashiwase) |
Website URL | http://www.kashiwase.co.jp |
Street address |
Tochigi Japan
[See map] |
Person in charge | - |
Capital | 20,000,000 JPY | Employees | 80 |
Annual sales | 1,600,000,000 JPY | EMIDAS Member Number | 65028 |
Type of manufacturing | Home electrical appliances / Construction material / Transportation equipment |
Large | Medium | Small |
Designing | Mold designing | Forging die designing Progressive die designing (light electrical) Progressive die designing (auto) Drawing metal press die designing General metal press die |
Development and production of prototype/Small-scale production | Machining | Machining/Handles small-scale production (order from 1 piece) |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Sheet metal protocol manufacturing Pipe bending Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing Mass production jig manufacturing |
Die manufacturing | Press die | Designing Manufacturing Drawing die Bending die Forming die Multi forming die Shaving die Progressive die Single press die 60 - 300 t Compound die |
Die manufacturing | Spring mold | Designing Manufacturing Spring die part processing Wire spring die Leaf spring die |
Die manufacturing | Forging die | Designing Manufacturing Cold forging die Press forging die |
Mass production | Metal press | Drawing Bending Forming Multi forming Shaving Coining Brass Phosphor bronze Stainless steel material for spring Thickness Thickness Single press (below 80 t) Single press (80 - 200 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) |
Mass production | Forging | Cold forging Press forging Below 500 g 500 g - 5 kg |
Assembly/Inspection | Assembly | Construction component assembly |
Assembly/Inspection | Inspection | Spring |
Parts manufacturing | Machinery part | Shaft and roller manufacturing |
Parts manufacturing | Spring | Thin leaf spring Terminal spring Compression coil spring Tensil coil spring Torsion spring Double torsion spring Leaf spring Shaped spring Battery spring Conical spring Formed wire spring Carbon steel Piano wire (carbon wire) Stainless steel Copper alloy Diameter Diameter |
Product manufacturing | Construction and civil engineering machinery manufacturing | Construction and civil engineering material manufacturing |
Product manufacturing | Others | Welfare equipment manufacturing |
