Most recent update: 2023-07-03
Company name |
株式会社 奥谷金網製作所 姫路営業所 (Okutanikanaamiseisakusho himejieigyousho) |
Website URL | http://www.okutanikanaami.co.jp |
Street address |
Hyogo Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 25 |
Annual sales | Unregister | EMIDAS Member Number | 65027 |
Type of manufacturing | Heavy electric machinery / Construction material / Transportation equipment |
Large | Medium | Small |
Material | Steel component distribution | Heavy plate Stainless steel Shaped stainless steel Perforated metal Expanded metal |
Material | Specialized material distribution | Molybdenum alloy |
Material | Nonferrous metal distribution | Flat steel plate Steel bars and shapes Copper and brass products Titanium Nickel Others |
Material | Plastic material distribution | PP (polypropylene) PE (polyethylene) |
Development and production of prototype/Small-scale production | Sheet-metal processing | Can manufacturing Sheet metal protocol manufacturing Deburring 3-roll bending 3-roll bending (2 m or longer) Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Shearing (longer than 121.2 m) CO2 laser machining |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding Arc welding Brazing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending |
Mass production | Metal press | Blanking Iron Stainless steel Aluminum Copper Brass Titanium Plated steel plate Nickel Thickness Thickness Thickness Diameter φ0.6mm - φ9.0mm Diameter Progressive press (35 - 80 t) |
Surface treatment | Plating/Chemical conversion treatment | Acid pickling |
Surface treatment | Polishing/Lapping | Electropolishing |
Surface treatment | Lap polishing | Lap mirror polishing |
Surface treatment | Other surface treatment | Buffing Shot blast |
Parts manufacturing | Other parts | Sign board manufacturing Filter manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Construction and civil engineering material manufacturing |
