Most recent update: 2023-12-01
Manufacturing( Die manufacturing / Casting die ) |
Company name |
有限会社 誉工業所 (Homarekougyousho) |
Website URL | https://www.homale.co.jp/ |
Street address |
Nagano Japan
[See map] |
Person in charge | - |
Capital | 3,000,000 JPY | Employees | 5 |
Annual sales | 80,000,000 JPY | EMIDAS Member Number | 62968 |
Type of manufacturing | Jigs and tools / Machine tools / Industrial machinery |
Large | Medium | Small |
Designing | Mold designing | Forging die designing Casting die designing General metal press die Extrusion molding die designing 3D modeling (press) 3D modeling (plastic) NC data creation (press) NC data creation (plastic) |
Designing | Product and part designing | External design |
Designing | Jig and tool designing | General jig designing Welding jig designing Mass production jig designing |
Designing | Simulation | 3D modeling |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Thread-cutting Iron Aluminum alloy Machining (resin) Milling (resin) Lathe machining (resin) Casting Urethane Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Handles 2.5-dimensional processing Handles 3D processing |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding Jig grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Brazing |
Development and production of prototype/Small-scale production | Jig manufacturing | General jig manufacturing Welding jig manufacturing |
Development and production of prototype/Small-scale production | Prototype processing | Welding prototype mold |
Die manufacturing | Press die | Designing Manufacturing 3D modeling Forming die |
Die manufacturing | Forging die | Designing Manufacturing Forging die part processing NC data creation Hot forging die Cold forging die Warm forging die |
Die manufacturing | Casting die | Designing Manufacturing Die-casting part processing NC data creation 3D modeling Die-casting die Shell moulding die Sand casting die |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Tapping machining Wire machining Electrical discharge machining |
Surface treatment | Heat treatment | Vacuum annealing Quenching Vacuum quenching High frequency quenching Carburized quenching Nitridation Gas nitrocarburizing |
Surface treatment | Other surface treatment | Shot blast Sound blast Glass beads blast Etching (surface treatment) |
Assembly/Inspection | Repair | Die repair |
Assembly/Inspection | Inspection | Forging Casting Measuring |
Parts manufacturing | Machinery part | Bearing manufacturing Crank shaft manufacturing Shaft and roller manufacturing |
Auto parts manufacturing | Drive system part | Steering device Brake parts |
