Most recent update: 2001-11-30
Company name |
ノダネーム株式会社 (Nodane-mu ) |
Website URL | http://www.nodaname.co.jp |
Street address |
Tokyo Japan
[See map] |
Person in charge | - |
Capital | 20,000,000 JPY | Employees | 25 |
Annual sales | 300,000,000 JPY | EMIDAS Member Number | 62951 |
Large | Medium | Small |
Designing | Electrical planning | PCB designing Other electronic part designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Machining/Handles small-scale production (order from 1 piece) |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | NC set press Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Angle machining Deburring Coating Mirror surface machining Hair line machining Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting CO2 laser machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | Spot welding TIG welding (argon welding) Stud welding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending |
Mass production | Metal press | Drawing Bending Blanking Shaving Iron Stainless steel Aluminum Copper Brass Phosphor bronze Plated steel plate Thickness Single press (below 80 t) Single press (80 - 200 t) |
Surface treatment | Plating/Chemical conversion treatment | Alumite (anode oxidation) Acid pickling Aldine treatment (aluminum chromate) Chemical conversion coating |
Surface treatment | Coating | Melamine coating Epoxy coating Metal coating |
Surface treatment | Polishing/Lapping | Electropolishing Chemical polishing |
Surface treatment | Printing and others | NC engraving Printing Silk screen printing |
Surface treatment | Lap polishing | Lap mirror polishing |
Surface treatment | Other surface treatment | Buffing Shot blast Sound blast Glass beads blast Etching (surface treatment) |
Assembly/Inspection | Assembly | Precision equipment assembly |
Parts manufacturing | Electrical part | Other electrical part manufacturing |
Parts manufacturing | Electric board and electronic part | Rigid board Electronic parts assembly and wiring |
Product manufacturing | Production property | Measurement/testing devices manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing |
