Most recent update: 2023-04-13
Company name |
三島光産 株式会社 (Mishimakousann) |
Website URL | http://www.mishimakosan.com/ |
Street address |
Fukuoka Japan
[See map] |
Person in charge | - |
Capital | 359,500,000 JPY | Employees | 2300 |
Annual sales | 30,000,000,000 JPY | EMIDAS Member Number | 62650 |
Type of manufacturing | Office automation equipment / Electronic parts / Transportation equipment |
Large | Medium | Small |
Designing | Mold designing | Injection molding die 3D modeling (plastic) |
Designing | Jig and tool designing | General jig designing |
Development and production of prototype/Small-scale production | Machining | General-purpose milling Deep hole drilling Iron Stainless steel High rigid material Aluminum alloy Copper alloy Simultaneous 5-axis machining Casting |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC lathe machining 5-face/5-axis machining Boring milling Machining (horizontal) Handles 3D processing |
Development and production of prototype/Small-scale production | Blank cutting | Cutting |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | TIG welding (argon welding) Plasma welding |
Die manufacturing | Plastic mold | Designing Manufacturing 3D modeling Injection molding die Below 60 t 60 - 300 t 000 t 000 t and over |
Die manufacturing | Glass mold | Glass mold designing & manufacturing 3D modeling |
Mass production | Plastic | Thixo-molding Below 60 t 60 - 300 t 000 t Injection molding 000 t Thin wall molding |
Surface treatment | Plating/Chemical conversion treatment | Iron Copper |
Surface treatment | Heat treatment | Normalizing Annealing Full annealing Stress relief annealing (SR treatment) Straightening annealing Quenching Salt bath quenching Solution heat treatment Sub-zero treatment Carburized quenching |
Surface treatment | Other surface treatment | High-speed frame spraying (HVOF) Spraying Shot peening/WPC Buffing Shot blast Sound blast Etching (surface treatment) Frame spraying Arc spray Plasma spray Tool and die coating |
Assembly/Inspection | Assembly | Precision equipment assembly Auto parts assembly Industrial machinery assembly |
