Most recent update: 2022-01-20
Company name |
サトウテクノパーツ (Satoutekunopa-tsu) |
Website URL | http://www1.odn.ne.jp/~aaj60120/newpage1.htm |
Street address |
Osaka Japan
[See map] |
Person in charge | - |
Capital | 3,000,000 JPY | Employees | 1 |
Annual sales | Unregister | EMIDAS Member Number | 61312 |
Type of manufacturing | Construction material / Machine tools / Transportation equipment |
Large | Medium | Small |
Material | Nonferrous metal distribution | Titanium Others |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Deep hole drilling Rolling Thread-cutting Spinning Machining/Handles small-scale production (order from 1 piece) High rigid material Aluminum alloy Titanium alloy Molybdenum alloy Broaching Keyway milling Automatic lathe Bench lathe machining |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining |
Development and production of prototype/Small-scale production | Electrical discharge machine | Electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Can manufacturing |
Development and production of prototype/Small-scale production | Blank cutting | YAG laser machining Water jet cutter machining CO2 laser machining |
Development and production of prototype/Small-scale production | Grinding processing | Plane grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding TIG welding (argon welding) Arc welding Robot welding Brazing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing |
Mass production | Forging | Header machining |
Surface treatment | Plating/Chemical conversion treatment | Nickel (barrel) Zinc (barrel) Chromate (general) Zinc (rack) Alumite (anode oxidation) Nickel chromium (rack) Electroless nickel (rack) Baking (hydrogen embrittling) |
Surface treatment | Lap polishing | Lap mirror polishing |
Surface treatment | Heat treatment | Normalizing Vacuum normalizing Annealing Quenching Vacuum quenching High frequency quenching Carburized quenching Nitridation Gas nitrocarburizing |
Surface treatment | Barrel polishing | Barrel finishing (rotation) Barrel finishing (centrifugal) |
Surface treatment | Other surface treatment | Buffing Shot blast |
Parts manufacturing | Bolt/Screw/Nut | Bolt/Screw/Nut manufacturing Screw manufacturing Bolt manufacturing Nut manufacturing |
Product manufacturing | Production property | Other industrial machinery manufacturing Carrier machine manufacturing |
Product manufacturing | Plant equipment manufacturing | Marine vessel equipment manufacturing |
Product manufacturing | Construction and civil engineering machinery manufacturing | Combustor manufacturing Construction and civil engineering material manufacturing |
Product manufacturing | Others | Transportation equipment manufacturing |
