Most recent update: 2023-02-01
Small-size prototype manufacturing( Development and production of prototype/Small-scale production / Prototype processing ) |
Part processing( Die manufacturing / Press die ) |
Sheet metal protocol manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Company name |
株式会社 オウミ (Oumi) |
Website URL | http://www.kk-oumi.co.jp |
Street address |
Kanagawa Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 35 |
Annual sales | 360,000,000 JPY | EMIDAS Member Number | 60733 |
Type of manufacturing | Industrial machinery / Transportation equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) Handles 3D processing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining |
Development and production of prototype/Small-scale production | Sheet-metal processing | Precision sheet metal machining Sheet metal protocol manufacturing Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Shearing Laser processing (longer than 121.2 m) Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding Brazing |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing |
Die manufacturing | Press die | Manufacturing Part processing Plate machining NC data creation Drawing die Bending die Blanking die Single press die 60 - 300 t Over 300 t |
Mass production | Metal press | Drawing Bending Blanking Coining Iron Stainless steel Aluminum Thickness Single press (80 - 200 t) Single press (200 - 500 t) |
Assembly/Inspection | Assembly | Auto parts assembly |
