Most recent update: 2023-11-17
Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Laser and turret punch press processing ( Development and production of prototype/Small-scale production / Blank cutting ) |
Progressive press (200 - 500 t)( Mass production / Metal press ) |
Company name |
株式会社 石黒製作所 (Ishiguroseisakusho) |
Website URL | http://ishiguro-builders.com |
Street address |
Saitama Japan
[See map] |
Person in charge | - |
Capital | 50,000,000 JPY | Employees | 20 |
Annual sales | Unregister | EMIDAS Member Number | 58736 |
Type of manufacturing | Industrial machinery / Telecommunication equipment / Construction material |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Sheet-metal processing | Can manufacturing Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Angle machining 3-roll bending Bending (hydraulic) |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser and turret punch press processing Corner shearing CO2 laser machining |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Robot welding Stud welding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending |
Mass production | Metal press | Drawing Bending Blanking Iron Stainless steel Aluminum Copper Brass Phosphor bronze Plated steel plate Thickness Thickness φ0.6mm - φ9.0mm Diameter Press robot (80 -200 t) Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) Progressive press (35 - 80 t) Progressive press (200 - 500 t) |
Mass production | Blank cutting | Fiber laser processing Thick plate 6 mm or more stainless |
Product manufacturing | Others | Telecommunication equipment manufacturing |
