Most recent update: 2022-07-22
Company name |
株式会社 金子製作所 松戸工場 (Kanekoseisakusho) |
Website URL | http://www.kaneko-ss.co.jp/ |
Street address |
Chiba Japan
[See map] |
Person in charge | - |
Capital | 48,000,000 JPY | Employees | 160 |
Annual sales | Unregister | EMIDAS Member Number | 5768 |
Large | Medium | Small |
Designing | Industrial equipment designing | Automatic machinery manufacturing |
Development and production of prototype/Small-scale production | Machining | Melt cutting Planer machining Plano miller machining Deep hole drilling Gear hobber Rolling Thread-cutting Profile milling High rigid material |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining 5-face/5-axis machining Boring milling NC facing |
Development and production of prototype/Small-scale production | Electrical discharge machine | Wire electric discharge machining Micro hole machining Electric discharge machining |
Development and production of prototype/Small-scale production | Blank cutting | YAG laser machining Water jet cutter machining CO2 laser machining |
Development and production of prototype/Small-scale production | Grinding processing | NC plane grinding NC cylindrical grinding Profile grinding Jig boring Jig grinding Cylindrical mirror grinding Internal grinding Centerless grinding |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | High-frequency welding |
Development and production of prototype/Small-scale production | Prototype processing | Plastic protocol machining Photoforming Punching Welding Bending Small-size prototype manufacturing |
Die manufacturing | Press die | Manufacturing Progressive die Transfer press die |
Die manufacturing | Plastic mold | Designing Manufacturing Injection molding die Blow molding die Expansion molding die Vacuum/Air pressure molding die Extrusion molding die Plastic magnet molding die Thixo-molding die Insert molding die Outsert molding die 000 t Electrode manufacturing |
Die manufacturing | Rubber mold | Compression molding die |
Die manufacturing | Casting die | Wooden model |
Mass production | Metal press | Drawing Bending Blanking Forming Fine blanking Multi forming Roll forming Transfer press (below 80 t) Transfer press (80 - 200 t) Transfer press (200 - 500 t) Single press (below 80 t) Single press (80 - 200 t) Single press (200 - 500 t) Progressive press (35 - 80 t) Progressive press (80 - 200 t) Progressive press (200 - 500 t) |
Mass production | Plastic | Blow molding Vacuum molding Extrusion molding Insert molding Outsert molding Expansion molding Plastic magnet molding Thixo-molding Injection molding |
Mass production | Rubber | Compression molding |
Surface treatment | Printing and others | Engraving |
Parts manufacturing | Machinery part | Gear manufacturing Vacuum components manufacturing |
Parts manufacturing | Electrical part | Harness processing Cable manufacturing |
Parts manufacturing | Electric board and electronic part | Rigid board |
Parts manufacturing | Bolt/Screw/Nut | Screw manufacturing Bolt manufacturing Nut manufacturing |
Product manufacturing | Production property | Electrical machinery and apparatus manufacturing Energy-saving equipment/Automatic instrument manufacturing |
Product manufacturing | Medical equipment manufacturing | Medical equipment manufacturing |
