Most recent update: 2023-06-02
Company name |
株式会社 澤幡製作所 (Sawahataseisakusho) |
Website URL | http://www.sawahatass.com/ |
Street address |
Ibaraki Japan
[See map] |
Person in charge | - |
Capital | 5,000,000 JPY | Employees | 28 |
Annual sales | 300,000,000 JPY | EMIDAS Member Number | 5597 |
Type of manufacturing | Heavy electric machinery / Jigs and tools / Transportation equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | General-purpose milling General-purpose lathe machining Tapping Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel Aluminum alloy Copper alloy Casting Honing Brass |
Development and production of prototype/Small-scale production | NC machining | Machining (vertical) NC milling NC lathe machining Boring milling |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | TIG welding (argon welding) Arc welding |
Development and production of prototype/Small-scale production | Casting | Low pressure casting Gravity casting Sand casting Aluminum alloy Copper alloy Aluminum bronze 500g or less 500g-5kg 5kg or more |
Die manufacturing | Casting die | Manufacturing Sand casting die |
Mass production | Mechanical processing | Machining NC milling machining NC turning machining Iron Stainless Aluminum alloy Copper alloy Casting Honing machining |
Mass production | Casting | Low-pressure casting Gravity casting Sand casting Aluminum alloy Copper alloy Aluminum bronze alloy |
Surface treatment | Polishing/Lapping | Buffing |
Surface treatment | Heat treatment | Straightening annealing Solution heat treatment |
Surface treatment | Other surface treatment | Buffing Shot blast |
Auto parts manufacturing | Engine | Fuel system |
