Can manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Stainless steel( Development and production of prototype/Small-scale production / Machining ) |
Precision sheet metal machining( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Sheet metal protocol manufacturing( Development and production of prototype/Small-scale production / Sheet-metal processing ) |
Laser and turret punch press processing ( Development and production of prototype/Small-scale production / Blank cutting ) |
Bending( Development and production of prototype/Small-scale production / Prototype processing ) |
Chassis prototype manufacturing( Development and production of prototype/Small-scale production / Prototype processing ) |
Company name |
福田板金 株式会社 (Fukudabannkinn) |
Website URL | http://fukudabankin.co.jp./ |
Street address |
Saitama Japan
[See map] |
Person in charge | - |
Capital | 10,000,000 JPY | Employees | 15 |
Annual sales | Unregister | EMIDAS Member Number | 5545 |
Type of manufacturing | Industrial machinery / Construction material / Medical equipment |
Large | Medium | Small |
Development and production of prototype/Small-scale production | Machining | Tapping Machining/Handles small-scale production (order from 1 piece) Iron Stainless steel |
Development and production of prototype/Small-scale production | Sheet-metal processing | Pipe machining Can manufacturing Air-conditioning equipment manufacturing Kitchen unit manufacturing NC set press Precision sheet metal machining Chassis manufacturing Sheet metal protocol manufacturing Bending (over 3.0 m) Angle machining Deburring Coating Mirror surface machining Hair line machining 3-roll bending Bending (hydraulic) Can manufacturing (over 5 m) Thin wall (Thickness |
Development and production of prototype/Small-scale production | Blank cutting | Turret punch press processing Shearing Cutting Laser and turret punch press processing Laser processing (longer than 121.2 m) Corner shearing CO2 laser machining Nitrogen cutting Thin plate (below 6 mm) Thick plate (over 6 mm) Stainless steel Copper/Aluminum |
Development and production of prototype/Small-scale production | Welding/Adhesive bonding | CO2 welding Spot welding TIG welding (argon welding) Arc welding Brazing Stud welding |
Development and production of prototype/Small-scale production | Prototype processing | Punching Welding Bending Small-size prototype manufacturing Chassis prototype manufacturing |
